Sun of a beach
Old Sep 11, 2002 | 09:46 PM
92 Red Firebird's Avatar
Sun of a beach
The sun seems to be fading my spoiler. is this common? i know that letting it sit in the sun doesn't help, but i've kept it waxed and protected all of the time. It seems as if the sun is just eating at the paint, and turning it into a white fade.
Old Sep 11, 2002 | 10:55 PM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
Very common. Take it to a good body shop, they'll charge you about $100 to repaint it and it'll look brand new.
Old Sep 12, 2002 | 10:18 PM
I'm having some trouble with the moulding on the doors. they seem to be fading also. could they be rplace or must they be painted too?
Old Sep 13, 2002 | 05:09 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Sounds like it is begining to delaminate. You need to get it repainted before it gets much worse or they will have to strip it all the way down to the primer and reseal it before repainting.
The UV damages the clear coat and then the UV gets to the sealer, which not UV resistant. It damages the sealer, so the paint falls off. That why all the old sealer has to come off in these areas. You see it as a white crusty color over the paint. I believe moisture is actually getting under the clear at this point causeing it to flake off. Not really sure on that point, but once it starts the affected areas has to go all the way back down to the sealer, or the repaint will do the same thing in a short time.
So you may want to go ask a good body shop about it, before it gets too bad to fix easily!
1MeanZ
Dec 18, 2015 05:39 AM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
lt1z350
Sep 29, 2015 01:50 PM
andy74
Sep 3, 2015 08:41 AM
