Help on Cleaning Rims
Old Sep 17, 2002 | 10:22 AM
PopaPork's Avatar
Hey my RS rims are startin to look a bit...crappy. I got like light stains, from whut I dont know, and some like road dirt/brakdust in all the little groves that I cant get out with my finger. Is there any special way to clean these bad boys? I aint talkin 89 show room condition or anything just make them look nice. Even after I was the car and do the rims up they still got junk on them and stuff. So if anyone has anyidea or any products let me know, thanks
Pork
Old Sep 17, 2002 | 10:37 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I find the Quiksilver II rim cleaner works well, with a brush.
Old Sep 17, 2002 | 11:20 AM
pardonme2711's Avatar
take it to your local do it your self car wash. load them up with grease lighting then use the pressure washer on them!
Old Sep 18, 2002 | 06:42 AM
redrs89's Avatar
I agree,Grease lightning does work good but don't let it dry up on your wheels.It will stain them.I use it for cleaning just about everything
Old Sep 18, 2002 | 09:21 AM
logikal6785's Avatar
wow. nice clean rim is grease lightning a national brand, bc i haven't seen it around here
Old Sep 18, 2002 | 09:31 AM
redrs89's Avatar
i think it is,try wal-mart or most autoparts store carry it.Or even try that purple stuff from castrol,use it full strength but again do not let it dry up!
Old Sep 18, 2002 | 09:48 AM
Car: 99 Formula
Axle/Gears: 342
BE VERY CAREFUL WITH GREASED LIGHTNING, that is extremely strong stuff, I recommended it to a friend years ago and it totally messed up his wheels. There are certain materials not to use it on. Just read the bottle.
Old Sep 18, 2002 | 02:55 PM
Supercharged84Z's Avatar
Car: 1984 Camaro Z28
Engine: 350 CID
Transmission: Beefed up 700R4
how bout GUNK? would that work?
Old Sep 18, 2002 | 05:46 PM
PopaPork's Avatar
So this Greased lighting stuff, just put it on then you like a scrubby pad or something and then hose off?
Old Sep 18, 2002 | 05:49 PM
redrs89's Avatar
yep
Old Sep 19, 2002 | 12:13 PM
dirtybird's Avatar
I used turtle wax has a rim cleaner its a two step procedure if you want a "protective coat" ok anyway its turtle wax and when sprayed on its a foam. It works awesome w/ my impossible to clean formula wheels, it got all the brake dust inbetween where the lugnuts are, i was amazed?! That **** has been there so long and so hard to get off. Well good luck.
Old Sep 19, 2002 | 12:17 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
I just use some brake dust remover that you get from the parts store. Just spray on and spray off at the car wash. Well after that I use the car wash brush. Seems to work ok.
birdman_29
Jan 7, 2017 08:24 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
raymondandretti
Sep 5, 2015 05:02 PM
