polishing question
Old Sep 21, 2002 | 03:12 PM
bigbrianiroc-z's Avatar
polishing question
alright im fixen to go clean my wheels and polish them. i just have a couple of questions. can i use a vibrating sander to sand? and do i need to put primer down befor i repaint the wheels? thanx for the help
Franks
Old Sep 21, 2002 | 03:45 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
The first person who tells him to search has to give me a dollar!
> say it say it say it!!!
I wouldnt use the power sander. Primer sounds good.
Old Sep 21, 2002 | 04:44 PM
i did a search befor i posted this. i was just wondering because everyone who did it did it by hand and i was just wondering if i did it with a sander if it would take less time.
Old Sep 21, 2002 | 05:27 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
I used the Black and Decker Sandstorm on mine with 110 then 220 grit paper. Then did the rest by hand 400-1500 grit. Worked well.
Old Sep 21, 2002 | 07:03 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Try a dremmel too, that would work well. I did my miniram that way and it came out sweet!
JACKO's Avatar
If ya use a sander be carefull not to round off your edges.
I'd do it by hand, with a firm block where possible.
Old Sep 21, 2002 | 07:17 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
DO NOT USE A DREMEL. It left burns marks in my rim, and polishing by hand for the polish part works just as well.
Definately, get an electric sander , will cut the process time in half.
Old Sep 21, 2002 | 07:24 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I've got an idea...
Old Sep 21, 2002 | 07:25 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
SORRY! You first off need to know which bits to use. I too had this "burning" problem when i started my miniram but when i figured out which bits to use, it was smooth sailing. Just watch what you are doing, that's all. What kind of sander would you use anyway, it depends on it's size. A dremel has a pretty good size to it to be able to move it around easier! I just watched what i was doing and the miniram came out perfect! Mark, ask Erik/es87iroc how it came out. He saw it when he picked up my groundeffects. I had good results from using it, that's all. good luck with your wheels
86IROC112
Sep 29, 2015 04:07 PM
gixxer92
Sep 1, 2015 04:32 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
kah992
Aug 19, 2015 02:55 PM
redmaroz
Aug 16, 2015 11:40 PM
