Installing shift light?
Old Oct 17, 2002 | 07:06 PM
84Z28_5.7ltr_V8's Avatar
Car: 1984 Z28
how would i go about installing a shift light on an 84 z28 camaro?
also, anyone know where i could find a do it yourself webpage about re-finishing camaro rims? thanks!
Old Oct 17, 2002 | 07:43 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
About the easiest way to add a shift light only is to buy the Proform shift light. It has a dail on the back indicating which rpm you'd like the light to came on at anywhere from 3000-11,000 Look in Jegs part# 778-67005c $49.99, you can get it cheaper at www.noerthernautoparts.com it's like $42 buck there. Buddy has it in his Malibi and it works great, just be sure to order the optional lens cover as all shift lights are BRIGHT at night. It just hooks into the coil tach side of the distributor, plus power and ground.
Old Oct 19, 2002 | 03:22 PM
Car: 1984 Z28
i see. The only reason i would want it is so i dont have to look down at the RPM and then ****, i usually do it by listening to the engine but it would be kinda cool to just have a light go on when u should shift. And in every camaro i have been in there is a little hole under the vents in the dash and i cant figure out why the hell it is there
Vintageracer
Jan 10, 2020 05:33 PM
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
drathaar907
Aug 6, 2015 04:20 PM
