Tyres
Old Oct 24, 2002 | 04:06 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
Tyres
whats the lowest profile tire I can get for a 17" rim, the rims are 17 x 9.5 I know everone runs 275/40 but is there anything lower.
Old Oct 24, 2002 | 04:18 PM
CrazyHawaiian's Avatar
Car: too many ...
i think everyone runs 45 series. you can also get 40 series (like you said) or even 35 series. but keep in mind getting lower profile tires will affect the overall dimensions of your rear tire which will also affect your speedometer.
Old Oct 24, 2002 | 10:33 PM
devianb's Avatar
You can definately go as low as 35, but you will have an extremly large fender gap. Our cars have a large enough gap as it is.
Old Oct 25, 2002 | 02:49 AM
taturbo's Avatar
Car: 3 3rd Gen F-bodies and 7 others
Engine: 305 CFI, 350 TPI & 3.8 Turbo V-6
Transmission: all automatics (stock)
In a 17" tire for that width of wheel, you are going to have a hard time finding a shorter sidewall than a 40 series.
If you go with a narrower tire, for example a 255 instead of a 275.
You will get a shorter sidewall. 40 stands for 40% of the tread width. So 40% of 255mm will be a little shorter, than using a 275/40R17.
How important is width, if you have a lot of power you probably don't want to downgrade to a narrower tire, but for a V6 or "Low Output" V8 a P255/40R17 should work fine.
The height difference is (275/40)25.7" diameter vs. (255/40)25.2", so only about a 1/2 inch difference in overall height.
Old Oct 25, 2002 | 03:13 AM
IROC_5796's Avatar
I was just thinking a lower profile tire would look good and fit better in the wells,
I want to lower the car as much as possible, iwas thinking coilovers in the rear to stiffen the ride and some kind of adjustable racing strut for the front.
I want to keep a little drivablitity, I just want the car to look good, I have too many tickets already for speeding and burnouts and racing, now racing is the worst you can get. So I just want to cruize in a nicley in a hard riding lowered car, I like getting whiplash on every bump.
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
blackbeauty
Sep 29, 2003 10:15 PM
Kiwi-85IROC
Mar 21, 2003 04:07 AM
89vette
Dec 3, 2002 01:15 PM
