test sig
Old Nov 6, 2002 | 03:39 PM
billsfirebird's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
test sig
.....hmmm......
Old Nov 6, 2002 | 03:43 PM
try again....
Old Nov 6, 2002 | 03:45 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Just for future reference, you can look at post posts and your sig will have automatically changed.
Old Nov 6, 2002 | 03:47 PM
I knew that I just wanted to get my sig attached so I could copy and past the location into my sig....but it doesn't seem to work. If I use open image in new window and copy and paste the location that should work shouldn't it? Ive got the img in front and back of the copied location. That should work right?
Old Nov 6, 2002 | 03:49 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Nope, wont work here.
Post in the readers rides. It will work from there...
Old Nov 6, 2002 | 03:54 PM
for some reason the readers rides section is giving me an error message every time I upload. If I edit the section it will tell me on the next screen that I tried to upload a file that is not a jpg. Even when I didn't even mess with an image.
If I do put an image in, a little window will pop open when I click the submit button.
you have tried to submit a picture with two periods, "." in a row.
What? I don't have two periods in the file?!!?!?!?! I did the exact same file as the one you see above. It turned out fine. ?????
Im using a mac and internet explorer but I don't think that could be the problem could it?
any help
Old Nov 6, 2002 | 04:41 PM
Car: 99 Formula
Axle/Gears: 342
any help
ahhh, i know someone had the same exact problem, they posted it on the problems board, and solved it, do a search on that board.
Old Nov 6, 2002 | 04:43 PM
thanks i'll check it out.
Old Nov 6, 2002 | 05:28 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
[img] http://pic1.picturetrail.com:80/VOL1...0/15472156.jpg[/img]
Old Nov 6, 2002 | 05:32 PM
FLYNLOW92rs's Avatar
www.cardomain.com
They can host pictures and you can link from there........
Old Nov 6, 2002 | 05:48 PM
83firebirdS/E's Avatar
Car: 1983 Firebird S/E
on a mac be sure you do .jpg at the end of the file name.
Linson
Oct 24, 2025 02:00 PM
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Eric-86sc
Sep 28, 2015 11:37 AM
