Headlight Adjustment
Old Nov 14, 2002 | 02:00 PM
abcx09t's Avatar
Car: 1987 IROC-Z; 2012 Ford Raptor
Engine: Modified 350
What is the proper and / or easy way to adjust the headlights?
Old Nov 14, 2002 | 02:46 PM
Firechick's Avatar
Car: 84 T/A,84 Bird,85 T/A Knight Automated Roving Robot
Engine: 305 HO many mods, 151C.I.D-stock,305 TPI stock for now
Transmission: 700-R4 Turbo Hydro-Matic
Park your car in front of a wall. Then adjust the two screws. One is a left/right adjustment , the other is a up/down adjustment. Your goal is to get them straight. The light from both lights should come together towards the end of the light given from the headlights.
Old Nov 15, 2002 | 11:09 PM
SRD's Avatar
SRD
I started high and kept going lower untill other cars stopped flashing their lights at me.
Old Nov 16, 2002 | 08:54 AM
Jza's Avatar
Jza
There's a tech article.
That last way works too.
Old Nov 17, 2002 | 04:30 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Pull your car up to a wall. Put a peice of tape level to both of your healight on the wall, then pull the car back 10 feet away from a wall, then have the headlights aimed exactly straight onto the two peices of tape you put on the wall. Try to keep them pointing inwards a "little bit" Gives you a better amount of light right in frint of you car crossing the beam ever so slightly about 40 feet infront of your car.
J-money
Jan 4, 2019 09:45 AM
Nervous2
Oct 8, 2015 10:53 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
