Lexan T-Tops, before and after polishing
Old Nov 23, 2002 | 01:27 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Decided to try to polish my lexan T-tops, they were looking pretty bad from the sun shining on them for 10 years, I polished the drivers side and put it back on the car to compare, all I can say is WOW what a difference. Notice the trees reflections. If anyone wants to do this I started with 3M 800 grit wet sanding paper, using lots of water, then after all the scratches were gone I used 1000 grit, then 1500 grit, finished it with an orbital polishing buffer with Meguiar's paint cleaner, then used Meguiar's polish to finish it. I did the corners by hand that the buffer wouldn't get, just don't leave the buffer in one spot and let it build up heat and it works great.
Old Nov 23, 2002 | 01:28 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
And another one.
Old Nov 23, 2002 | 01:31 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Wow! Thats quite an improvement! Looks like glass
Old Nov 23, 2002 | 01:33 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
DUDE! You should quit your job and polish tops for people on this site cuz thats pro work right there!
Old Nov 23, 2002 | 03:08 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
That is great work! What type of buffing compound did you use??? And how long did it take per side??
Old Nov 23, 2002 | 03:10 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Very impressive man! Keep up the good work. Any pics of the finished product or maybe the whole car?
Old Nov 23, 2002 | 03:58 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Cruzin Kaz, see the first post for the products I used, it took about 30 min. of hand rubbing and about 10 min. with the buffer on the first side.
86IROCNJ, I'm still working on the passenger side, then I need to repaint the trim where I rubbed the paint off of it at, I tried taping it off but the tape got in the way of hand rubbing too much so I just took it off, I'll post a finished picture when I'm done.
Old Nov 23, 2002 | 04:39 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Looks good, nice job.
Old Nov 23, 2002 | 04:54 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
nice! here is a pic of mine
(wet sanded with 600, 800, 1000 and 1500 grit + a few hours of polishing)
Attached Thumbnails Lexan T-Tops, before and after polishing-polished_t-tops.jpg
Old Nov 23, 2002 | 05:30 PM
JACKO's Avatar
Great job, did mine a while back makes a real differance
Old Nov 23, 2002 | 07:03 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Guess I should have read it better. Oops
Old Nov 23, 2002 | 07:49 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
Zaino sells a glass polish that works real well. Removed my hard water spots like a champ.
Old Nov 23, 2002 | 07:52 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Someone really has to post a pic of this Zaino product. I haven't heard anything about before till I got on this web site. It must be more of a American product??? I've been detailingfor 13 years now. Never seen it or used it. Hmmmmm.... I wonder?
Old Nov 23, 2002 | 09:53 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Looks great, thanks for sharing...
Old Nov 23, 2002 | 10:34 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Looks very good guys! Makes me want to go polish my wheels....
Old Nov 23, 2002 | 11:46 PM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
Yea, let me start out by saying my t tops are pure crap when it comes to finish al-together. I tried to clean the rust off of the frames and used crappy touch up paint for it, that doesn't look good. And the tops are scratched to heck due to being neglected by the previous owner. I can just use a regular wood sander w/ the wetsanding paper on it and then buff them out starting at 300, then to 800, then 1500? It'll work good? I was pondering this idea a week ago, guess it can be done, by the way, that looks AWESOME!!
Old Nov 24, 2002 | 02:59 PM
MdFormula350's Avatar
great work!!
Old Nov 24, 2002 | 04:19 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
wow, looks good. nice work
Old Nov 24, 2002 | 05:24 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
PimpRod92RS,
I would not recommend using a regular power sander for it, it should be wet sanded by hand or it might build up too much heat and clog up the paper and or warp the panels, wet sanding is a no-no with a power sander anyway unless it's cordless, the wet sanding will give it a very dull appearance till you do the final buffing then it will shine.
Old Dec 4, 2002 | 03:09 PM
Thank you DartbyU. I appreciate your concern for my well being, I could have messed up my panels. So your saying I should hand sand them with wedsanding paper at the grits mentioned above in the correct order, with water, and it will look good? Thanks again, I'm gonna try to fix these crappy t tops
Old Dec 4, 2002 | 03:34 PM
demonspeed's Avatar
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
http://www.zainobros.com
Old Dec 4, 2002 | 09:53 PM
LastViceRS's Avatar
Car: '91 RS
Engine: LO3, For now...
Those look great, guys - I'm gonna have to try that.
Old Dec 5, 2002 | 12:30 AM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Does this only work on lexan tops? Also, what years did the camaros have the lexan option ?
Old Dec 9, 2002 | 06:20 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I believe Lexan tops were used starting in 89 or 90, heard they quit using them in 91 due to warranty problems, then they came back for 92 which is what I have, I guess they didn't fix the problem very well because they don't hold up to the weather very good. You can polish glass you just have to do it differently, there are special glass polishes you can buy.
Old Dec 9, 2002 | 09:15 AM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
Really nice job man.......can believe what a difference that is. Good stuff.
Old Jul 6, 2003 | 09:39 AM
FastChick's Avatar
WOW that looks REALLY REALLY good, now I'm going to have to go do mine, they look pretty bad and I had thought about trying to polish them but I didn't think Lexan could be polished, but it looks like it can Hope mine turn out as good.
Old Jul 6, 2003 | 11:24 AM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
Repolished my t-tops this week. I'm starting to really like them.
Old Jul 6, 2003 | 12:11 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
the T-Tops are made out of a acrilic Material, T-Tops are not really lexan. I'm not sure if you had lexan windows you could buff them or not.
Old Jul 7, 2003 | 03:42 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Are yours glass or plastic? Also, I've never heard of Innotec???
And finally, what process did you use to get yours to look like that?
Old Jul 8, 2003 | 08:37 PM
Grimaldo's Avatar
So can you do the same things to plastic ones?
Old Jul 8, 2003 | 10:11 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
They're plastic. I sanded my tops with 240, 320, 400, 600, 800, 1000, 1500 and then buffed them. I haven't heard of Innotec either. It's just some generic polish that I found in the garage, but works surprisingly well on plastic.
/edit: http://www.innotecna.com
Old Jul 8, 2003 | 10:35 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Looks good man, Do the taillights also if you haven't, it makes a world of difference.
Old Jul 8, 2003 | 11:01 PM
Grimaldo's Avatar
the tailights?
Old Jul 8, 2003 | 11:34 PM
Car: 91 RS
Engine: 350 TBI
I suppose you're talking about wet sanding by hand??
Old Jul 9, 2003 | 08:47 AM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
Yes, I did the sanding by hand. And it works great on the taillights, too.
Old Mar 21, 2008 | 07:34 PM
RS305's Avatar
Car: 92 25th Anniversary RS
Engine: 305ci 5.0L V8
Re: Lexan T-Tops, before and after polishing
is there any way to buff by hand (without any special machine)?
Old Mar 25, 2008 | 03:24 AM
JACKO's Avatar
Yeah you can use fine wetsand paper and cutters but you would be better off buying a cheap electric buff to give you a better result and you will be able to use it on your paint as well. Most cheap buffs are made in "ChingChong" land and they cost sweet "FA" and last a long time for the home user. 3m have some good products to use and so has Ferecla when dealing with plastics
Old Mar 25, 2008 | 06:08 AM
full house's Avatar
theres no change! what do you really want to happen on you Lexan?
Old Mar 25, 2008 | 01:25 PM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
very good info.
what would you suggest on a car with painted t-tops? yes, thats right, painted t-tops. start with a slightly more abrasive grit or keep with what the write up says?
Old Mar 25, 2008 | 02:26 PM
RS305's Avatar
i guess ill just get a cheapy buffer
Old Mar 30, 2008 | 01:03 PM
RS305's Avatar
i got my tail lights in the other day, and decided to clean them up. they were in good shape, except that the lenses were cloudy and dirty like my old ones. since they weren't scratched at all, i decided to clean them and polish them with some meguiars plastx plastic polish using my mothers power ball. i gotta say, it worked DAMN GOOD! all of the dirt and grime came off easy and the tail lights look new. i also used this method on my grimy bumper lights and it made them look great too! say goodbye to dirty lookin lights and lenses
Old Jun 25, 2012 | 01:34 AM
  #42
Twiztid Tim's Avatar
Car: i have a 1991 camaro rs
Engine: 5.0
Axle/Gears: stock
my t tops are so crappy looking!wet sanding them with 80 grit would prolly make them shine more!im so glad i was able to find this tip it was the hole reason for getting online thanx for tip i kinda had the idea to use one of them lens resto kits but i like wet sandding idea better thats the same consept for getting orange peal and dust nibs outta pant jobs and makeing them shine thanxs looks great
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
