polishing plenum
Old Nov 24, 2002 | 12:26 PM
91 z28 350's Avatar
Car: 91 Z28
polishing plenum
When i polish my plenum what would be better to use the mothers mag and aluminum polish or the mothers billet polish
Old Nov 24, 2002 | 01:54 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Re: polishing plenum
Not real sure....I have always used the mag and aluminum polish....works really well.
Old Nov 24, 2002 | 02:24 PM
MdFormula350's Avatar
close that hood my eyes hurt from the shine
Old Nov 24, 2002 | 02:27 PM
Engine: 5.7
LOL, thanks man.....I'm going to redo the plenum next spring though.....still has a couple in-perfections in it....I need to sand a little bit more....."The more you sand, the better it will look!!"
Old Nov 24, 2002 | 03:20 PM
MG86TA's Avatar
My whole engine bay is an imperfection.. stop complaining! :lala:
Old Nov 25, 2002 | 01:10 AM
Kandied91z's Avatar
neither if possible.............try some other products out there as there are better results.
i personally like wizards; picked up at most professional body shops and works really well. doesn't haze as much which is a plus. mothers tends to fill in pores to easily as well as haze which makes for more work.
Old Nov 25, 2002 | 01:47 PM
theSteve's Avatar
Car: 1985 Trans Am
Engine: upgrading...
Transmission: upgrading...
rofl.
Old Nov 25, 2002 | 02:44 PM
Vicious 88 GTA's Avatar
SHINY!!
If I were to polish my TPI set up with mothers would it look that good, and if not what supplies would I need??? AARON
Old Nov 25, 2002 | 02:52 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
check the tech articles section. It's alot of sanding and buffing to get it to look like that. No polish will EVER make a stock plenum look like that.
Old Nov 25, 2002 | 03:46 PM
Engine: 5.7
Re: SHINY!!
I used Mother Aluminum Polish on my plenum and runners....and I'm very happy with how it turned out. In order to get a mirror like finish....you HAVE to sand the "cast" look out of it though. If you just use the mothers polish on the plenum without sanding.....it won't do much at all......
This is how mine turned out with Mothers on my 1991 Z28 5.7 L98...I would really like to try the stuff what Kandied91Z was talking about too......
Old Nov 25, 2002 | 03:49 PM
Kandied91z's Avatar
no replacement for serious elbow work..........
but polish compound can make all the difference. i actually go over it with a thick grade and then some finer elements like jewelers rouge and then a chrome polish to seal it.
time consuming yes; but the shine will be brighter and last longer this way which means less detailing time!
Old Nov 25, 2002 | 03:51 PM
Engine: 5.7
Where can you get this compund at? would automotive paint shops have it?...they carry...alot of compounds....just wasn't sure about aluminum or metal poshing compounds...
Old Nov 25, 2002 | 04:10 PM
Kandied91z's Avatar
well i know the stuff i use is made by wizards and you can either pick it up on the internet or just about every major body shop that does good work around here keeps some in stock.
i use a heavy grit paint polish to start then go over with their metal polish and finish up with a chrome polish or if i'm out i use a finish coat of one of my paint polishes. either wizards or zaino.
looks and works great.
Old Nov 27, 2002 | 10:44 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
TRIPOLI works great for polishing also. I like the shin it gives better then White rouge
Mothers has a new billet polish anybody try that yet?
Old Nov 27, 2002 | 11:07 AM
87transam5.7tpi's Avatar
white rough is the best polishing compound for aluminum. I do this for a job, I know. do the sanding, white rough, then a LITTLE aluminum polish. thats is your best bet.
Old Nov 27, 2002 | 01:07 PM
Jza's Avatar
Jza
Do the sanding, then the tripoli, then the white rouge, then a little wax.
Old Nov 27, 2002 | 06:41 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Next question... where to get white rouge?
Old Nov 28, 2002 | 07:32 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
If you go to sears they sell a kit, it has 3 buffing wheels and a bit to mount them to a drill, i also comes with 4 type of polishing compoung, not a bad deal, i think its like 20-25 bux. after you get all the rough stuff and are ready for a cream polisher, give the blue magic metal polish a shot, it has silicone in it to protect, and give a good luster.
Old Nov 28, 2002 | 09:26 AM
Nasty_Bird_'90's Avatar
I polished my setup a while ago. I sanded the casting off with a belt sander the second time I did it, that made it alot faster. Then i worked my way up to 1000 grit sandpaper. After I got to that point, I whipped out the polishing wheel. Started with 'emory', then used 'tripoli' and then a 'white rouge'. You can go even farther with a 'jewlers rouge' but to me it's not really that much better. After the white rouge I polished with Mother's aluminum polish and it shined like chrome.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
