Help with rims
Old Dec 2, 2002 | 01:32 PM
Fivespeed85's Avatar
Car: 85 Trans Am TPI
Engine: Big Enough
Help with rims
I want to put 93+ rims on my 85 trans am, however, i've been told that i will need 2.5" spacers, is this true because i think that is wide. Anyways, is there anything else i can do and if spacers are the only way, will they be strong enough to handle the torque?
Thanks.
Old Dec 2, 2002 | 05:05 PM
caspergotaz28's Avatar
Car: 1992 Camaro Z28
Re: Help with rims
Thanks.
Yes, you will need spacers. If you go with a reputable company they will be strong enough to handle the torque.
Good sources for the spacers are www.vettebrakes.com and www.skulte.com
Old Dec 2, 2002 | 08:43 PM
MdFormula350's Avatar
what rims were you thinking about?
Old Dec 2, 2002 | 10:34 PM
Engine: Big Enough
These rims, they're EagleAlloy 16" rims and they say that they fit camaro and firebirds 1993 and up. I had a set of stock 95 trans am rims but same story, they sat in too far...the edge of the rim touched my inner wall on the rear without tires but i didn't know if the 2.5 inch spacers would be too much or what, or even if they would handle to torque without snapping. That would suck to have to sacrifice some performance for looks but more so if they did rip loose, it would be really expensive for me to fix a problem like that. Thanks for everyone's help so far
Old Dec 3, 2002 | 07:28 AM
97-1LE's Avatar
Car: 87 Trans Am
Engine: Built 350 Cam, Headers
Transmission: 5 speed
If the off set is the same as the 4th gen wheels, then I think 2" adapters will work.
Old Dec 10, 2002 | 11:24 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
2.5" adapters are usually too much for rims that are made to fit the 4th gen. We usually recommend 2" adapters for that application. If you're not happy with the fit, you're welcome to exhange them for a different (or custom) size.
http://www.skulte.com/adapterfaq.html
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
kitt23
Exterior Parts for Sale
Nov 28, 2015 06:26 PM
dbrochard
Oct 10, 2015 01:03 PM
dbrochard
Oct 10, 2015 01:02 PM
