wheels that dont require spacers??
Old Dec 6, 2002 | 11:26 AM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
Hey i was just wondering what wheels there is besides the stock 3rd gen wheels that i could use without having to buy spacers...i want to buy some new wheels but the price alone for the wheels is gonna break me, let alone another 300 just for spacers...thanks
Old Dec 6, 2002 | 12:23 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
I believe ROH's don't require spacers
Old Dec 6, 2002 | 12:34 PM
CrazyHawaiian's Avatar
Car: too many ...
Alot of companies make wheels that will fit. Performance Wheel Outlet has some that will fit w/o spacers. So do most billet wheel manufacturers (American Racing, Budnik, Boyd, Etc). Do some searching on the net and call the manufacturers individually to see whats up. Thats what I did.
Old Dec 6, 2002 | 03:59 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
cool thanks, i thought that just about every wheel had to have spacers cuz of the different offsets front and back
Old Dec 6, 2002 | 04:24 PM
Jza's Avatar
Jza
www.fikse.com
Old Dec 6, 2002 | 04:32 PM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
mine fit.......AR's Hopster
Old Dec 7, 2002 | 02:14 PM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
There are lots of wheels that will fit a thirdgen, but you have to know what you're looking for. Most of the stuff like TireRack, and so forth, have a limited selection for thirdgens, but if you go to the wheel manufacturers, you can find the stuff that will fit.
Keep in mind that the thirdgen shares a bolt pattern with the S-10 pickup, so there are other sources for wheels
Things to know:
Bolt pattern- 5x4.75
For an 8 inch wide rim, use a wheel with 4 inches of backspacing. This is the same as a stock front wheel. The stock 16x8 rims use slightly different backspacing front to rear, but using the same wheels all around only makes the rear track about 1/2" wider.
For a 9.5 inch wheel, the accepted backspacing is 5-1/2 inches. This is commonly regarded as the widest wheel you can fit on a thirdgen, but there are some people running 11" rims on the rear.
Old Dec 7, 2002 | 03:12 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
right on, i feel better now, i have just heard everybody talking about spacers on here and i knew there had to be more wheels that would fit, now i just gotta decide what i like, i like the tt2s but every1 has them...
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
