Ground Effects
Old Dec 16, 2002 | 11:50 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Ground Effects
I would like to change the ground effects on my 82 Z-28, is there anything that will bolt onto the currrent ground effects? What about front air dams, i saw one in JC Whitney about a year ago? What about ground effects off a later car like 91-92? Are aftermarket kits any good, i've seen them for $600.
I want my car to look lower and closer to the ground. What would you recommend?
Old Dec 16, 2002 | 11:55 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
I know for the 91-91 gfx you would need an 86 or newer nose if i am correct. that about all i know sorry im not much help.
Old Dec 17, 2002 | 09:39 AM
MdFormula350's Avatar
91 - 92 z28 ground effcts should work..
Old Dec 17, 2002 | 10:01 AM
bradkeith's Avatar
You will need a 85- and up nose. You will also need to drill holes in your front fenders, weld metal brackets under your doors, drill holes in your doors, drill holes behind the doors, and drill holes in your rear quarter panels. It's not really that hard to do .
Old Dec 17, 2002 | 12:51 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
your EXACTLY right! I had a 1984 Z28 (same apperance as the 82) and I had to replace the nose...1985-1992....drill new holes.....a bunch of modifications to make my 84 a clone of a 1992 Z28....I added the rear highrise spoiler too.........there is noway that a 1985-1990 (Z28, RS, IROC-Z) or 1991-1992 (RS,Z28) front nose ground effect wil fit a 1982-1984 Z28 front nose......
Old Dec 17, 2002 | 11:05 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Alright thanks!
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
lewandom
Oct 1, 2015 08:15 AM
Damon
Sep 26, 2015 04:29 PM
