Show ways you have taken wieght from your car.
Old Dec 21, 2002 | 07:05 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
I would like to see what you all have done, if you have done any at all, to take wieght from the car, yet keep the stock appearance. I hope to chop a bunch of pounds from my car, but it must look no differant than it looks now. Thanks to all...
Old Dec 21, 2002 | 07:06 PM
85_ZED28's Avatar
Car: '85 Z28
This topic comes up alot, try a search
Old Dec 21, 2002 | 07:08 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
I have done a search, just very, very few actual pictures....
Old Dec 21, 2002 | 07:15 PM
85_ZED28's Avatar
Car: '85 Z28
oh sorry man, didn't know you were looking for pics
:lala:
Old Dec 21, 2002 | 08:31 PM
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
TTT, I want to know as well.
Old Dec 21, 2002 | 09:47 PM
IROC57TPI's Avatar
I heard somewhere about taking the front bumper cover support out and replacing it with a thin piece of angle stock. Its supposed to weigh like 45lbs.
You know the typical stuff so I'll just post unique ideals.
I also go rid of the carpet sound deadner, the rear seat lower cushions (invisible if you fold the upper rear seat down), and the power antenna for a stationary one. I got rid of the power seats and put manual 4th gens in. Thats all I can think of for right now...
Old Dec 22, 2002 | 12:05 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i pulled my A/C that helped a lot. My sound deadener really weighted a LOT. Although everyone else said theirs didn't. Maybe mine was trapping moisture or something but it was easily 15-20 pounds.
I pulled out the heat and all defroster ducts until i can find a non A/C box from the junkyard.
I also removed the sway bars for a little while but i'm putting WS6 ones in since driving wasn't as much fun on the street for the benefits. Well there's a motor pic with no A/C or Heat on my new thread. Feedback DEFINATELY welcome.
Old Dec 22, 2002 | 12:24 AM
MdFormula350's Avatar
no spare tire stuff..
Old Dec 22, 2002 | 02:26 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Any pictures of aftermarket k-members, lighter stuff in general? Thanks.
Old Dec 22, 2002 | 07:18 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Sorry, no pics. For stock appearance and 'some' weight savings, you might swap in the hollow 36 mm front sway, throw in an alum drive shaft and the so-called 1LE alum spare.
JamesC
Old Dec 22, 2002 | 04:11 PM
Kandied91z's Avatar
unless going chromolly the tubular member only knocks off a couple of lbs in the steel, quite alot for the price. sure looks cool though.
besides ripping out the ac and emissions there isn't a whole lot.
you could go with a brake setup that uses aluminum 2 piece rotors. that will knock off roughly 3-4 lbs of rotating mass off each wheel and add a lighter driveshaft like the aluminum or carbon fiber to knock off 10-12 lbs as well. those will make the most street difference as it's the rotating mass that gets you.
100lbs for every .1 isn't worth stripping important things like seats and the like. unless your in contention and then you wouldn't be asking.
personally though i'd go with the rotating mass before anything as it makes the most difference.
Old Dec 22, 2002 | 04:55 PM
formul8!!'s Avatar
Car: 2004 GTO
I removed:
-all A/C stuff
-Spare tire stuff
Will be changing:
-to fiberglass Formula replica hood
-fiberglass spoiler
-aluminum bumper supports
Old Dec 22, 2002 | 05:12 PM
dsaint1347's Avatar
Lose some weight and ride solo.
Old Dec 22, 2002 | 05:17 PM
PopaPork's Avatar
Some one IM NJSpeeder. He is the weight ****. I am sure he has pictures of it. If he could he would race in his underware...cuz shoes, pants, blets, t shirt and socks weigh tooooo much haha
Old Dec 22, 2002 | 05:40 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Just got done a few days ago installing my PA Racing K member...I also got their tubular a arms but I have no pics of those yet. I should be able to get some more photos in a couple of days. But I got the mild steel setup with spring perches. This thing is LIGHT. The chrome moly vesion is a couple pounds lighter but a lot more pricey.
Attached Thumbnails Show ways you have taken wieght from your car.-mvc-497s.jpg
Old Dec 22, 2002 | 05:42 PM
IROCZZ3's Avatar
Car: 87 Buick GN
And one more...
Also note the clearance between the oil pan and cross tube. You should be able to drop the pan without jacking the motor. Motor mount swaps are a breeze now but I changed mine while the K member is out.
Attached Thumbnails Show ways you have taken wieght from your car.-mvc-499s.jpg
Old Dec 22, 2002 | 06:27 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Originally posted by IROCZZ3
And one more...
Dat's purdy. :hail: How much $$$?
I'd love to do something like that to mine. IIRC QwkTrip did that same k member (Chromoly though) and it shaved off ~35lbs. So I'll bet you shaved at least 28-30lbs off yours.
Other tricks to take off weight are aluminum heads. Stockers weigh about 40lbs each bare, and aluminums usually weigh about 28lbs each.
I saw one guy gut a factory size battery, cut out the bottowm and shoved a DynaBat in there. It looked completely stock. Your battery weighs about 35lbs. The DynaBat weighs 13lbs.
Doing those two things will take off another ~45lbs.
Headers are normally lighter than stock manifolds, albeit not a lot.
Aluminum radiators are worth a few pounds. Maybe 3-5lbs?
PLUS....... Get a hair cut, trim your nails, wear low cut tennis shoes, take a dump, and loose all your pocket change.
Every little bit helps.
Old Dec 22, 2002 | 06:28 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
I want that. How much and where can I find it? thanx
Old Dec 22, 2002 | 06:35 PM
92Transam's Avatar
Have you read this yet? https://www.thirdgen.org/newdesign/t...ngpounds.shtml The total weight lose after doing all thats stated in this article is 275 lbs.
Old Dec 22, 2002 | 06:48 PM
FLYNLOW92rs's Avatar
You need to focus on the stuff that moves to save the weight....
Also i did the following stuff...
Removed Heater (core, hoses, etc)
Removed spare tire stuff
That's about it....
www.vfnfiberglass.com
They have STOCK fiberglass parts for the camaro....pricey, but going fast and looking good cost money......
Old Dec 22, 2002 | 08:08 PM
IROCZZ3's Avatar
Car: 87 Buick GN
It's made by www.parcing.net but I got it through www.thunderracing.com
Old Dec 22, 2002 | 08:17 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Believe it or not, weight savings was secondary as to why I got it. I did it cuz I needed another K member....my old one got a huge dent in the middle when I hit a big rock one day (see 1st pic I posted, you can kinda see the dent). I figured since I'm going through the trouble of replacing it might as well put something in there I really like so I bit the bullet and got one....
Old Dec 22, 2002 | 09:35 PM
EvilCartman's Avatar
Car: '82 Z28
So are those K members fine for a daily driver or strickly race only?
Old Dec 22, 2002 | 10:42 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
You could always get an Aftermarket Fiberglass Hood.....they way alot less then the stock metal hoods.....
Old Dec 22, 2002 | 11:45 PM
Kandied91z's Avatar
if your going to use them for daily driving i wouldn't go with anything other than the steel. even they say so. it would probably be fine for a cruiser although a car that is a true daily driver i wouldn't think you would want to spend that kind of money. but to each his own, definately looks killer.
Old Dec 23, 2002 | 12:37 AM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Throw out the computer and all unecessary wiring, (that is, if you have or plan on bypassing the computer.)
Oh and FLYNLOW92rs, I would hate to be you stuck on the side of the road with a flat tire.
Old Dec 23, 2002 | 01:45 AM
Camarokid01's Avatar
From the factory my car has manuel windows and locks, no power antenna, but I have taken out the AC compressor, AC cooler(in front of radiator), removed all emissions stuff (AIR, EGR), aluminum intake manifold, fiberglass hood, removed jack and spare, taken out computer and wiring harness. Thats all I can think of right now.
Old Dec 23, 2002 | 09:56 AM
Engine: 5.7
I'm not sure I get what your saying?? The fourth gen SS Camaro's and the Ram Air Trans Am hoods are all fiberglass......and even back like in 1982 the Z28's (can't remember exact year) came out with fiberglass hoods.......I've never had any problems with any fiberglass hoods....and they are fine for daily driver cars.....I'm not trying to start anything at all...trust me....I just don't understand why you think that fiblerglass hoods can't be used on daily driver cars....
Old Dec 23, 2002 | 10:23 AM
billsfirebird's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
thats a pretty interesting piece. I like the clearance you gain with it too. Im sure it is real easy to replace motors and such with it because the mounts are easy to get too! Good looking project.
Old Dec 23, 2002 | 11:10 AM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
im thinking hes talkin about the k-member.....mild steel vs chrome moly.
Orr89RocZ
Apr 25, 2016 08:28 AM
69 Six Pack
Oct 5, 2015 07:51 PM
TheExaminer
Aug 26, 2015 04:59 PM
Hello, Michael
Aug 20, 2015 03:19 PM
