got a new grant GT steering wheel
but my car is a 91, and has airbags. I have read the article how to get it out but what i still have one more problem. I need to buy and adaptor kit for it to fit my car, and there are no adaptor kits for 91+ cars. They have 3 in stock that are for a Trans am up to a 1990. Will that adaptor kit work on my car? do the steering wheels hae the same bolt pattern?
I was also wanting to put a Corsa GT wheel from Grant in my '91, so I sent them an email and they told me that if my car was equipped with EITHER air bags or cruise control the wheel would not fit (they said I could try and learn the hard way). They said that if it didnt have either, I could use kit #3196. There has to be SOME WAY to make these steering wheels fit into air-bag/cruise control third gens!! Has anyone done it???
Joe.
Joe.
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Fatal88 should know, they have had that car apart more times than some people change oil in thier cars....
Car: 86 Z28
Axle/Gears: TBD
3196 is the kit you will have to either cut air bag wires or find a way to take them out of the top of the column but either way after that it will fit.i just did it. screw the air bag mine was DOR dead on removal. if you need help i'm here
Car: 86 Z28
Axle/Gears: TBD
yes that is for the grant adaptor. all you are looking for basicall is a kit fot the cthirdgen w/o ait bag.
oh and you might want to take out air bag light bulb from dash
Joe.
Car: 86 Z28
Axle/Gears: TBD
well here is the deal my car has cruise and everything i installed a replacement column. At the same time i installed wheel
you will not even see cruise control equip
just a steering shaft after you take off wheel and every thing.
just follow instructions in package and make sure to note that there is a center mark on the steering shaft
and on column
and on column
Cool, then it will work huh? I wonder why they told me it will not work with a cruise control car?? So your's still works right? Would I have to install a replacement column too, or should mine work with the factory column? What did the replacement column come out of (what type of car), or was it an f-body column? Sorry for so many questions, but I would hate to buy this steering wheel and it not work! Thanks.
Joe.
Joe.
Car: 86 Z28
Axle/Gears: TBD
when i installed mine i saw nothing having to do with the cruise control. unless your wheel has cruise settings on the wheel you have nothing to worry about. and no you will not need a replacement column.
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
