odd bar, hanging down ! i cant live with it anymore!!!!!!!!!!
Old Jan 7, 2003 | 01:11 PM
600_dollars's Avatar
okay this is freeking pissing me off!!!!!!!!!! everytime i hit the brakes or **** i get a horrible scrapping sound or a wierfd bang.. !
well i figured it out.. everyone was like " its the exhaust" .. well its not! i found it ! its some wierd bar coming off of the rear axel? .. ( sorry i am pretty new to old american cars..) .. well its just hanging .. someone said it might connect to the tranny but i have aafter market tranny .. so what now?!
I am about fo junk the t/a if i cant figure this out.. ( you dont understand how annoying this is )
Old Jan 7, 2003 | 01:32 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
Got a picture?
Old Jan 7, 2003 | 01:36 PM
Trux's Avatar
Car: grand prix/84 z28
Engine: 4.6 Northstar
Transmission: t-56
umm...
It could be the sway bar but I dought it. I think it is that toeque arm. It connects your rearend to your tranny. That would explain the noises easily.
Old Jan 7, 2003 | 01:39 PM
Re: umm...
Yes thats what someone said it is .. i think?..
where does this mount to? .. where do i put it ? can i take it off ? cut it off? weld it somewhere?
Old Jan 7, 2003 | 01:53 PM
Trux's Avatar
Transmission: t-56
torque arm
The torque arm connects to the transmission by a rubber mounth. It can be removed with a socket. There should be two bolts bolting it on. The torque arm conencts dirrectlly to the rear end. Usually on teh passenger side. There are 2 bolts and nuts holding the arm in place. If this is the first time taking it off you may want to buy a torch (to heat the bolts, makes it alot easier) and some wd 40.
It is not hard but if it is the first time it may take about 40 minutes.
There are aton of aftermarket torque arms around.
You probably need a new mount to the transmission too. There is probably worn out and cause the arm to come loose after hitting a bump or something.
Old Jan 7, 2003 | 02:00 PM
Re: torque arm
The torque arm connects to the transmission by a rubber mounth. It can be removed with a socket. There should be to bolts bolting it on. The torque arm conenctr dirrectlly to the rear end. Usually on teh passenger side. There are 2 bolts and nuts holding the arm in place. If this is the first time taking it off you may want to buy a torch (to heat the bolts, makes it alot easier) and some wd 40.
You probably need a new mount to the transmission too. There is probably worn and cause the arm to come loose after hitting a bump or something.
there is NO mount on the tranny .. where would i get one ? do you have a part number? or a what is it called?
Old Jan 7, 2003 | 02:08 PM
Trux's Avatar
Transmission: t-56
ummm..
I know there some be a ton of aftermarket ones.
I have to goto work , pretty soon and I will look there for some info. I work at napa.
I'll report back later
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
what kind of tranny do you have?
the mount would be called a torque arm mount.
Old Jan 7, 2003 | 02:17 PM
Trux's Avatar
Transmission: t-56
=D
Hey,
I found this at spohn, http://www.spohn.net/index.cfm?fusea...t&productid=90
That is the mount.
right now I have 700r4. But I am planniing on putting a t56 or something 6 speed in.
Old Jan 7, 2003 | 02:23 PM
Re: =D
Hey,
That is the mount.
does it matter what kind of tranny i have? .. i 'll have to get under the car to find out ..
Old Jan 7, 2003 | 02:26 PM
Trux's Avatar
Transmission: t-56
Umm...
I am not sure right now. I don't think it matters but I will find out when I get to work.
What do you have for a tranny?
Old Jan 7, 2003 | 02:31 PM
Dewey316's Avatar
Car: 1990 Camaro RS
if it is a t56 , or something with diffrent demisions that the tranny from the factory, then it will matter.
i think anyway. i could have sworn you had to actualy modify the torque arm for a t56.
Old Jan 7, 2003 | 02:39 PM
could i simply weld this on somewhere ..
Old Jan 7, 2003 | 02:51 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Here's the only reference pic of one I have (not the best either since I wan't taking a pic of it), keep in mind, it's on a 5speed. I might be able to get a pic of an auto later tonight since the trans from my camaro is getting ready to be donated to my friends truck.
Attached Thumbnails odd bar, hanging down ! i cant live with it anymore!!!!!!!!!!-tamnt.jpg
Old Jan 7, 2003 | 03:13 PM
I have a 5 speed also , yes and mine is missing that thing that goes around it ... what is it bolting into .. i'll get under there and take a pic tonite ..
Old Jan 7, 2003 | 03:19 PM
scott's85T/A's Avatar
It dose matter what tranny you have and I have never heard of someone removing the torque arm but you might be able to do it,,??? I know if you have a 350 tranny (3 speed) you will need a bracket that is sold by B&M to have a place to bolt to.But if you really have a 700r4 then you should have a place for a bracket to bolt to the back of the tranny and the other 1/2 of the bracket locks to the first on the bottom and has bolts holding it all together on the top,,with rummer bushings on the insides of both 1/2s'
Hope that helps.
Old Jan 7, 2003 | 03:22 PM
can i just have it welded?... somewhere.. ? =o)
i think i read taht taking it off is *BAD* .. damn i am at a loss.. should i just sell the damn thing?
Old Jan 7, 2003 | 03:40 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
Yes it would be bad.It stablizes the pinion angle of the driveshaft in relation from the rear axle to the transmission.It suppose to also stop the flexing of the rear I think.
Old Jan 7, 2003 | 06:06 PM
MdFormula350's Avatar
yeah you kinda need to get that fixed.
Old Jan 7, 2003 | 06:24 PM
well here is a pic ? my friend just rigged it up with a coat hanger..
for some reason i dont think its going to hold
Attached Thumbnails odd bar, hanging down ! i cant live with it anymore!!!!!!!!!!-pdr_0019.jpg
Old Jan 7, 2003 | 06:26 PM
another angle
Attached Thumbnails odd bar, hanging down ! i cant live with it anymore!!!!!!!!!!-pdr_0016.jpg
Old Jan 7, 2003 | 06:29 PM
91Zman's Avatar
Car: 1991 Z28
I assume that that's a temporary fix.
Old Jan 7, 2003 | 06:32 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
looks to me like the bracket itself is damaged, you may need to go to a junkyard and get the whole assm. (both brackets and the rubber bushing)
I know what kind of transmission i have .. " borg and warner" ...
Old Jan 7, 2003 | 06:44 PM
EvilCartman's Avatar
Car: '82 Z28
Looking to go poll vaulting driving that thing?
Old Jan 7, 2003 | 06:47 PM
umm thats a scary thought, okay i need to fix it , i guess my only alternative is to have my buddy weld it in place..
Old Jan 7, 2003 | 07:07 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Holy Sh<x>it.
<p><x></p><p><x></p><p><x></p><p><x></p>
Don't weld it...you just need a small bracket that wrap around the tip of the arm and bolts to the bracket on the tranny...it will have a piece of rubber insulator mounted to it . Sandwich the tip between the two rubber pieces and bolt it on the top.
I can also see where the arm has been making contact with the floor pan upon accelerating.
Do not drive the car until this gets fixed!!
Pete
Old Jan 7, 2003 | 07:09 PM
Originally posted by Petes 84Z28
Holy Sh<x>it.
Pete
THanx pete , you guys are great, do you know where i could find this magical part ? =o) .. what i should tell the auto store?
Old Jan 7, 2003 | 07:14 PM
Might try a salvage yard first...make sure it is from 5-speed thirdgen, as the automatics used a different style mount. V6 and V8 pieces will be the same. I'm not sure if this is a parts-store part or not
Pete
Old Jan 7, 2003 | 08:40 PM
deadbird's Avatar
Engine: TPI 305/ v6
From the looks of it, an 'engineer' got ahold of that and couldn't get it back together so it turn into a f-it project.
You don't really need the part that is bolted to the tranny as it appears to only be bent upwards to 'hook' the torque arm when it swings towards the ground. With a little bending/hammering you should be able to get that fairly close to it;'s original shape (red line in pic). All you need after that is the rubber mount and the outside retaining piece which is the same for auto or manual (yellow). If you can't find one, you could have some one bend you up some flat metal to close in shape to retain the rubber mount and then weld it (the bent flat stock to the other original half)together. A temporary/emergency fix would be to put some hose clamps around it and snug them up. It would at least be a little more peace of mind than (what looks like) a bent half of a bracket and some speaker wire.
Attached Thumbnails odd bar, hanging down ! i cant live with it anymore!!!!!!!!!!-tqrmmnt.jpg
Old Jan 8, 2003 | 12:32 AM
5SIZ's Avatar
Car: 1987 IROC-Z
oh my ***!
Damn dude, your lucky your car hasn't povaulted or the torque arm hasn't ripped through your floor pan yet, jeez.
do not drive the car and fix that problem A.S.A.P.
Old Jan 8, 2003 | 06:33 AM
91BlkRS's Avatar
holy ****!! i didn't think you could drive around with that loose. you're damn lucky it didn't go through the floor pan or throw your car.
Old Jan 8, 2003 | 09:07 AM
its not speaker wire , its a hanger =o)...
anyways i am going to go scour the junkyard this weekend .. now it drives fine if i take off in 2nd , and shift directly to 6th..
and if i am easy on the brakes .. any thoughts on what i should tell the junkyard i am looking for ( there usually all mexican workers and its hard as hell to talk to them )
Old Jan 8, 2003 | 09:44 AM
91Zman's Avatar
Car: 1991 Z28
just print out a picture of it and show them what you want that.Sorry I don't know the exact name for it but I just say that it's the torque arm mounting bracket by the tail of the manual transmission. :lala:
Old Jan 8, 2003 | 03:18 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
some people at junk yards arent too swift... ask them for the Torque Arm Mounting Plate from your model/year car with a 5 speed manual. If they still look baffled, tell them its the part on the tailshaft of the tranny. Your DAMN lucky you didnt kill yourself driving like that. If that would have caught something on the road, your car would have gone end over end.
Old Jan 8, 2003 | 03:29 PM
Nitroburn's Avatar
Dude... DO NOT DRIVE your car until you get that fixed!! As previously mentioned, you're damn lucky that you haven't busted through the floorboard or poll vaulted that car yet!
That long arm, which is now just dangling loose, keep the rear axle from twisting itself out from under the car during accelerating or downshifting.
Thing about this... When you nail the gas down that front of the car raises up. The reason for this is when under torque, the rear axle housing is trying to spin. That long bar (a/k/a torque arm) prevents that from happening, raises the frontend so that wieght is transfered to the rear of the car for traction.
So, do you kind of get the picture of what can happen to your car if you drive around without that bar mounted properly?
Good luck...
-Mike
Old Jan 8, 2003 | 07:43 PM
Car: '82 Z28
QUIT DRIVING THE DAMN CAR UNTIL IT'S FIXED PROPERLY!!!
Old Jan 8, 2003 | 07:56 PM
deadbird's Avatar
Engine: TPI 305/ v6
I was close
Old Jan 9, 2003 | 06:51 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
You can drive around without it connected but it is not recommended. The arm will only make contact with the ground when you give it more gas then nessicary in reverse. I've broke two mounts. As far as I know there are no aftermarket versions available. The Spohn torque arm relocates the mount to the x-member if I'm not mistaken. I'd try your GM parts counter.
Matt
Old Jan 9, 2003 | 08:31 PM
Fastcamaro87's Avatar
FYI : the auto and manual peices are completely different, both peices of the mount are different all together, I know because i was putting my trans back in today, and i couldnt find the outside half of my mount, so i went and yanked one off a 700r4 i have sittin around , and it wouldnt work without a lot of modifications. lucky for me i found the other peice.
Mark_ZZ3
May 24, 2018 01:02 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
83RDRACR
Mar 26, 2016 08:13 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
