polishing plenum
Old Jan 7, 2003 | 06:17 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
polishing plenum
i just started to polish the plenum, its a real pain to do, i started with 120 grit figured that it would be a good place to start.
I cant seem to get rid of these little pits in the aluminum, should I keep sanding, or are these little pits always going to be there and they wont show up to bad later when I apply the polish.
Old Jan 7, 2003 | 06:31 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
Keep on going. I know what you mean......it seems like it takes forever to get them out but they will eventually. IMO but i think that doing a wet sand takes more off the then dry does. I did last summer......took a while...but definetly worth it. Just take your time and before you know it...youll be seeing yourself in it..
Old Jan 7, 2003 | 07:01 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Yep....the main thing is....KEEP SANDING!.....any kind of pits....or imperfections....will come out...but...you just have to keep sanding. I know it kinda of sucks...but when your done....you'll be glad that you did it!
Old Jan 7, 2003 | 07:05 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Isn't the distributor cover plastic?
Old Jan 7, 2003 | 07:16 PM
Engine: 5.7
Yeah from the factory....they came molded in plastic...the Z28's were cheated...and got plastic covers... The L98 TPI Corvettes came with Aluminum distributer covers...so....I ordered one for my 1991 Z28 5.7 L98....sanded and sanded...and polished...and it came out pretty sweet..!
Old Jan 7, 2003 | 07:22 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Where did you get it from?
Old Jan 7, 2003 | 07:38 PM
IROC_5796's Avatar
Im gunna keep on sanding, if you figure wetsanding would remove more surface area Ill give it a shot, I wasnt going to start wetsanding till 400.
Im going to the autoparts store later and pick up wet 120 and 220.
Any polish recomondations?
Old Jan 7, 2003 | 07:42 PM
Engine: 5.7
Ordered it from right here....if you decide to order it....make sure to get the 3 screws too.....the orginal screws will not work with the aluminum cover....www.corvettecentral.com
Old Jan 7, 2003 | 07:58 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Thanks alot man.
Old Jan 8, 2003 | 01:36 AM
gtaguy87's Avatar
Car: 1998 Ram Air Trans am
Engine: Ls1
Transmission: 6 speed manual
how much was the aluminum cover
Old Jan 8, 2003 | 02:01 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I think mine was $20 at the dealer ship.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
