plastic on console
Old Jan 11, 2003 | 11:12 AM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
plastic on console
Hey, I'm trying to cut out places for my window switches and power mirror switch on the plastic console cover in my '85 T/A, but not having much success...using a jigsaw works, but the plastic melts back together as soon as I pass through it. Does anyone have any suggestions or tips to make it easier? Thanks!
Old Jan 11, 2003 | 11:24 AM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
dremel, maybe throw some water to cool it down before it goes back?
Old Jan 11, 2003 | 11:40 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
i actually used a sodering iron with a hotknife attachment. it worked great.
Old Jan 11, 2003 | 12:03 PM
lasher_350's Avatar
Engine: 5.7 L98
Okay, I have a soldering iron, but not the hot knife attachement...and I don't have a dremel, which I wish I did, because those things come in handy alot. Maybe I'll go to Home Depot and look for both of those things today. Thank you very much for the ideas, because mine just wasn't working too well!
i'm open to even more, so don't be shy! ha ha ha
Old Jan 11, 2003 | 12:11 PM
DSLDUDE2001's Avatar
Car: 2001 Camaro SS
Transmission: A4
We used a drill to get a hole to put a blade in, and then used a coping saw (just a little hand saw). It worked out great, but did take a little more time than what a dremel might take.
Old Jan 11, 2003 | 11:41 PM
HamSpiced's Avatar
ive you use a hot knife be careful to do it in like small segments, dont try to do it all at once.. youll heat up the plastic around it and it might distort and flex when u go to cut...
Old Jan 12, 2003 | 12:06 AM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
I just did mine a few weeks ago. Drill a pilot hole first and then use a small metal cutter from a dremel....works great. mine came out perfect.
MrPackstin
Oct 25, 2017 08:09 PM
Lbibb
May 5, 2016 12:00 AM
ndndndnd
Sep 28, 2015 08:00 AM
Night rider327
Sep 25, 2015 04:19 AM
codeysabatini
Sep 20, 2015 11:36 AM
