Question about putting in clear lenses...
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
So I opened up my hood, look at the clips inside, and I have no idea how to take out the old amber side markers??? I tried squeezing the clips, I tried moving them, but I think it would help me to know EXACTLY how I take them out?!?!?
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
The side marker lights are easier to get to from underneath the car. The actual lenses are held in by cotter pins. The bulbs are simply pressed in then turned. You should be able to spin the counter clock-wise and they should pull straight out.
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
the clips for the lenses are easy. just pull them up so they are at a 90 degree angle, then pinch it and the clip should come right out.
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
push the pin over to the other side and then try to lift the pin up, like jiggle it....then it should come loose.....i just put in my clear ones yesterday......i did the passanger side one from the engine bay and the drivers side one from underneith....although i do have me airdam off tho....
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
These are cotter pins:
yah um... i still don't understand a single thing any of you said... can someone shoot me a video or something
Engine: LG4
not to be sarcastic or anything but did u even look at them? i mean i am a retart and i figured it out right as soon as i looked at it.....if u just push it to the side it will slide out....
Car: 1990 RS
Engine: too small
Transmission: broken
The clip holding the lights in is facing one way flip it the other way and it might take a little jigglin but it should slid out. Then just put the clear one in and reverse the process.
um... i don't think mine is a clip then
mine has these 4 brackets, they're like in the same of a U upside down, and they are set up in the 4 corners like this:
u u
n n
then these pins, i think it's 2, go and link the bottomleft one to the topleft one (one there), and the bottom right one to the topright one (another), and and this pin has a pigtail in the middle of it. the pin looks kinda like this
n--------o--------n
that would be the sideview i guess.
u u
n n
n--------o--------n
Engine: LG4
yeah that is what we all got...just do what i said and it should work out fine for u.....just mess around with it....u will understand it better when lookin at it
Car: 1990 RS
Engine: too small
whatever you want to call them just flip them over (they are probably pretty tight) use a little elbow grease and they will flip over and loosen. Then just wiggle them a little and try both ways and the will slid out. Then take out the light, put in the new one and put them back in and flip them over. When done they should look just like they did before, if they are loose you did it wrong.
Not too tough.
Not too tough.
