Armrest cleaning questions...
Old Jan 28, 2003 | 04:44 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Well the last time I was cleaning out the car, I noticed that the arm rest for the doors were getting a little bit more black than they should. Wanted to clean them up, but I didn't know what works best, and what I DO NOT want to use. Is there anything that I can do to restore the to showroom quality look? They are tan.
TIA
PS If you have pictures of before and after, or even just after. Post 'em up!!!
Old Jan 28, 2003 | 05:57 PM
1982chevycamaroz28's Avatar
do not use armorl enless u want to keep using it alot. use migures (sp) or black magic. if u start using armol and stop it will dry out what u put it on.
Old Jan 28, 2003 | 06:00 PM
Abubaca's Avatar
I use Murphy's oil soap.
Old Jan 28, 2003 | 10:20 PM
88txiroc's Avatar
I have used Armor-All Mulit-purpose cleaner. It works really well on armrests and such. Just spray it on, let it soak a minute, then clean it off. I had the same problem with my tan armrests, and that did the trick.
Old Jan 29, 2003 | 08:21 AM
Sweet, I will probably try both of those. I just want to keep it clean!!!
Old Jan 29, 2003 | 08:29 AM
Topless91RS's Avatar
Car: 1991 Camaro RS Vert
Engine: 305 (L03)
Transmission: 700 R4
Tuff Stuff Interior Fabric cleaner, takes all the dirt and crap off and then use one of the other products. I found this out cleaning my door panels, the foam fell on the arm rest and when I wiped it off there was this really clean spot on my arm rest!
Old Jan 29, 2003 | 10:25 AM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
I the arm rests are vinyl....You can plobably use simple green safely. I actually used the purple Power Clean degreaser, but I sprayed it on a tooth brush and scrubbed the spot and then wipe it down with a water dampened towel. The stuff is strong and I would not let it soak in. Just a quick scrub & wipe off. It will take off all the old appiled protectant and dirt that has been trapped and give a slightly dull finish ready for Black Magic. I swear by Black Magic. It has plasticizers in it that soak in and restore the piece to its fully hydrated condition.
For leather I used Murphy's oil soap...
gta892000
Aug 11, 2019 11:16 AM
sailtexas186548
Feb 17, 2017 03:07 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
WhteRbt
Sep 21, 2015 09:48 AM
