3gen wheels on my 2gen???????
Old Feb 6, 2003 | 11:58 AM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Hey guys,
Long time no see...lol. I got a quick question. A friend of mine is sell a set of 16X8 Formula wheels. My question is, Will these fit on my 1976 Firebird Formula? I know that the bolt pattern is the same, and the rear wheels have a 5mm. offset to them.... Will this cause any problems?
Moderaters, I did read Brad's post priyer to posting this thread, I hope it has enough thirdgen content to stay open to atleast long enough to get an answer. If not thats okay too.
Thanks,
Rob
Old Feb 6, 2003 | 12:08 PM
MarkB's Avatar
Car: 1982 T/A -1986 Z28
Engine: 383 -305
Transmission: T56-700r
yes they'll fit...dont qoute me but...i hadda buddy who put 16x8 gta wheels on his 2nd gen bandit t/a...and he put the rear gta wheels on the front..and the front gta wheels on the rear...has to do with the offset...those wheels should look good once yo uget them on your 2nd gen...good luck..and post a pic or two once there on..id like to see.
Old Feb 6, 2003 | 12:35 PM
fiream's Avatar
Engine: 400HP 350
OKay that sounds about right. I wonder why he put the offset wheels up front, maybe they stuck out in the back or something.....ummmmmmmm.
thanks for the info,
Rob
Old Feb 6, 2003 | 01:15 PM
JimmyG-91Z's Avatar
There is a guy around here with an 80 Z28 and has Iroc rims on it so it can work somehow
Old Feb 6, 2003 | 05:11 PM
robs91conv's Avatar
I had an 81 Z28 that I put 82 Z wheels on. The only problem that was encountered is the shop put the 82 Z lugs on the 81 wheel studs. The 82 lugs were metric and the studs were standard. I drove about 10 miles before the lugs stripped and the wheel fell off. Luckily I was going very slow and no damage was done. The shop paid for all new lugs to be put on that were compatible with the studs.
Old Feb 6, 2003 | 06:27 PM
fiream's Avatar
Engine: 400HP 350
OKay, but will I run into a problem with the 15mm of backspacing???
Rob
Old Feb 6, 2003 | 07:52 PM
robs91conv's Avatar
I would ask the guy if you could try before you buy. That way you would know for sure if you are going to run into any problems before you actually buy them. Some people will let you do this; some people will not.
Old Feb 6, 2003 | 09:35 PM
fiream's Avatar
Engine: 400HP 350
Anybody else?
Old Feb 6, 2003 | 11:21 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Originally posted by fiream
Anybody else?
Putting the fron't son the back and vise-versa will cause the same a-arm rubbing problem on a 2nd gen as would a 3rd.
I sold my Formula wheels/tires to a friend with a 70 camaro (he was in need of them) and did the front/back exchange thing and his A-arms ate the inner part of the wheel.
Might be a exclusive thing to his car but, it didn't work as supposed to in his case.
Old Feb 7, 2003 | 09:56 PM
3SLO5's Avatar
Car: all over the place
Engine: the best one around
Transmission: lots of them
Axle/Gears: richmonds
yes you can put third gen wheels on a second gen fronts on rear rear on front , as stated the upper controlle arm rubs so some grinding and trimming is needed and the little wheel spacers help.also you need to use the stick on wheel weights not the kind that goes on the edge you can run 265/50r16 in the back and 245's up front. i have a 81 camaro with 86 iroc rims that i took from the iroc that i had befor selling it.for more answers to your 2nd gen needs go to nastyz28.com
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
