Magnum TPI from GMHTP...
Old Feb 21, 2003 | 09:35 PM
IROC57TPI's Avatar
is posted for sale on www.camaroz28.com. I didn't know where else to post this, but I wanted to see what you guys thought...
http://web.camaross.com/forums/showt...ferrerid=15171
They want almost 10,000 for a 12.0 second car. They wasted their money on that car if you ask me.
Old Feb 21, 2003 | 09:52 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
396ci that runs 12's.
I agree with you, they wasted their money.
Old Feb 21, 2003 | 10:09 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
Although I agree they made their mistakes, the car is probably worth close to it... assuming the body is in good condition and interior and such. A 396 with GEN 7 DFI and a super ram was it? Is it cheap, not to mention the rest of the items. I won't say I'd pay 10,000 but there is probably over that invested.
Old Feb 21, 2003 | 10:15 PM
Ions91Z28's Avatar
Actually, after reading their ad, and seeing exactly what they have in terms of the engine... that's not a bad deal at all.
Old Feb 21, 2003 | 11:38 PM
9T1 Z-28's Avatar
Engine: 5.7L TPI
Actually it runs consistant low, low 12s with no power adders. It has broken into the high 11's on occasion. Keep in mind that the project called for a COMPLETELY smog-legal setup. This car is smog certified in NJ.
I think that mostly it just has some tuning issues. Its a steal IMO because the motor, DFI, and full BAER brake setup are worth more than $10 alone. That's not counting the bulet proof tranny, new interior, suspension, and wheels and tires.
They have also listed it here in the classifieds. Here is a list of mods:
396 Engine: - block machined, torque-plate honed and blueprinted, .030 over - Pro-Gram Engineering billet main caps - Cola forged race crank, 3.875-inch stroke - Lunati Pro Mod billet rods - custom Lunati forged pistons (11.1:1 compression) - CNC-ported hand-finished AFR 190 cylinder heads - ported ACCEL SuperRam intake - 1000-cfm ACCEL throttle body - 26 lb./hr. ACCEL injectors - mild custom Competition Cams hydraulic roller camshaft - Comp Cams Pro Magnum stainless steel rocker arms - Comp Cams heavy-duty hydraulic roller lifter conversion kit - Engine dynoed at 485 hp w/holley carb and single-plane manifold - custom 4-inch inlet pipe & K&N filter - air conditioning converted to R134a refrigerant - SLP 1 ¾-inch Jet-Hot coated headers - SLP stainless cat-back exhaust (TOTL) - twin high-flow Random Technologies catalytic converters - Evans/Griffin aluminum radiator - Evans water pump & pulley - Spal dual electric fans
cont...
Old Feb 21, 2003 | 11:39 PM
9T1 Z-28's Avatar
Engine: 5.7L TPI
continued.....
Ignition: - ACCEL 300+ ignition - ACCEL coil - ACCEL Billetech distributor - MSD wires w/ACCEL high-temp heat socks
Transmission/Drivetrain - 700R4, Level 10 rebuild, boost valve and shift kit - Precision Industries 3000-rpm stall converter - stock 3.27 gears in Australian 9-bolt posi
Rolling Stock - ROH ZS wheels, 17x8.5 front, 17x9.5 rear - Yokohama A520 tires, 255/45R17 front, 275/40R17 rear
Interior - S&W 6-point roll bar w/swing-out side bars (NHRA legal) - Simpson 5-point harness on driver side (expires next year) - Year One interior (carpet, console, shifter plate, radio plate, embroidered floor mats) - Sony CD player
Brakes - Baer Track kit (front) - Baer Touring kit (rear) - PBR street pads
Suspension - Hotchkis adjustable Panhard - Hotchkis lower rear control arms - Hotchkis/Energy Suspension bushing (entire car) - Hotchkis lowering springs (cut one-third coil in front) - Hotchkis subframe connectors (welded) - rebuilt steering linkage (bump steer kit, tie rod ends, drag link, idler arm) - Moog strut bearing plates (front) - Bilstein struts and shocks
Engine Management - ACCEL Gen 7 DFI w/wide band control (needs new sensor but runs fine now) - Fast Track Performance jumper harness (for stock ECM control of emissions equip.) - Cotton Performance in-tank fuel pump
Old Feb 22, 2003 | 01:37 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
I've read up on it a few times, it does seem to have tuning issues which they talk about in this months issue. The wide band O2 sensor was not working properly and a few other things. All in all, if I had the money I would buy it, do some minor work to it and add about $750 worth of Funny Fumes and be in the high 10's. But I'm not being realistic so...
I wonder if they are throwing in the "Crack Pipe". LOL
Old Feb 22, 2003 | 01:47 AM
formul8!!'s Avatar
Car: 2004 GTO
It would cost you 20K + to duplicate this car.
It is a total deal!!
The motor alone is about $5,000+. The DFI is another $2,500, the roll cage $1,500, the car itself $5,000, rims&tires $2,000,etc...
"They want almost 10,000 for a 12.0 second car. " Jeeeeeez....
Old Feb 22, 2003 | 04:41 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
Not a bad deal. I would get it if i had the money
Old Feb 22, 2003 | 06:26 AM
IROC57TPI's Avatar
Sorry but its slow for all of the money they spent. I could make a TPI car go 12's with less than $5000 investment. A 396 should pull 11's all day long.
I think the car is worth $10,000 to the right person, but not to me.
Old Feb 22, 2003 | 10:38 AM
formul8!!'s Avatar
Car: 2004 GTO
Guess what? In the May 2003 issue coing out now, it pulled an 11.96 e/t.
Ok, so the car doesn't run 9's for $10,000. The whole suspension is done, interior redone, etc....
Look past the e/t and you will find a total bargain!
Hmmmmm....maybe I need a parts car for my Formula....
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
Sanjay
Aug 12, 2015 03:41 PM
