where can i mount an extra set of gauges on my bird?
Old Feb 24, 2003 | 08:38 PM
V6camaroman's Avatar
title says it all. where can i mount a dual gauge set with oil temp and trans temp on my 87 firebird. i already have the dual gauge pod with vacuum and water temp so that ideas used up. there are really no other places i can see where u can mount the dual gauge holder. does anyone have any ideas? if u do do u have pics to show what it looks like.
Old Feb 24, 2003 | 08:57 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Get a cowl hood and put them in the opening. Or..What if you were to get a tripple gauge pod and then mount the fourth on the dash under the lowest of the others? Or what about a custom pod down where the cig lighter is.
Just some thoughts.
Brian
Old Feb 24, 2003 | 09:03 PM
ChaosRanger's Avatar
Car: 1984 F41 T-Top
Transmission: 5 speed
How about a pillar pods ... here is one from Jegs
Old Feb 24, 2003 | 09:05 PM
i was just thinking wouldnt it work if u just turned the gauge holder sideways and mounted it on the side of the center counsil that holds the radio and heater? another thought. i thought i had seen a pic of that similar set up in someones car on this board.
Old Feb 24, 2003 | 09:17 PM
does anyone have pics of where they mounted their extra gauges besides on the gauge pod in firebirds. thanks for your time
Old Feb 24, 2003 | 09:21 PM
1986z28's Avatar
Car: 86 z28, 87 IROC, 88 sc, 93 z28
Engine: LG4, LB9, LO3, LT1
Transmission: 700r4, T5, 700r4, 4L60
Axle/Gears: 3.73, 3.45, 2.73, 3.42
put them in cups to the right of the stock gauges under the ac vents, I am curently switching to all autometer gauses and I have three under ther 2 on the a pilar and the tach and speedo in stock locations with fuel in the middle of them. If you searh there a good many member who have done just that.
Old Feb 24, 2003 | 09:23 PM
1986z28's Avatar
johnsjj2 has done it, hopefully he wont mind if i post a pic he sent me, looks really great.
Attached Thumbnails where can i mount an extra set of gauges on my bird?-gauges_seat2.jpg
Old Feb 24, 2003 | 09:26 PM
91FIREBIRDGT's Avatar
Car: 1991 Firebird
Engine: 3.1LV6
well i was thinking about this, if you don't mind losing your AC vents in the middle I think you can customize something there to fit at least one guage. Then you can just then get the triple pod for the a pillar.
Old Feb 24, 2003 | 09:38 PM
deadtrend1's Avatar
heres where i put my shift light .... you cant really do what Johnsjj2 did because bird dashes are stretched out furether.
Old Feb 24, 2003 | 09:40 PM
1986z28's Avatar
sorry, here i am posting pictures of a camaro when you have a bird I thought from the name it was a camaro, I need to read more carefully
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
