How to remove side view mirror glass?
Old Mar 8, 2003 | 10:51 PM
burnouts4ever's Avatar
how do i remove the side view mirror glass from the side view mirror without breaking it? thank you
Old Mar 8, 2003 | 10:53 PM
harry's91rs's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
Yeah, I've been wondering this also. My next mod requires me to remove the mirror from the plastic backing without breaking it.
Old Mar 9, 2003 | 02:50 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Im interested also. I am going to replace the entire mechanism and glass soon. Thanks in advance.
Old Mar 9, 2003 | 05:16 PM
glassman's Avatar
try a thin piano wire w a sawing motion in between the mirror and plastic backing plate or just bust it and dig it out w/screwdriver and buy anew one
Old Mar 9, 2003 | 09:53 PM
Breadfan's Avatar
It is glued on to the plastic frame for the power window motor . Between the glass and the plastic frame is a foam insulator . My mirror glass fell of , cought it before it came completely off. I then used a 2 part epoxy to reattach it to the the plastic frame . My car is a 86 t/a and i couldn't find just a glass insert for it , so i reused the old glass .
Old Mar 10, 2003 | 02:01 PM
I am interested in replacing the "guts" of my mirror. I want to remove everything except the mirror housing itself. My mirror has gone all wonky and I have a replacement that I want to feed thru the door. Any help would be appreciated.
Old Mar 10, 2003 | 05:41 PM
Breadfan's Avatar
If you have everything , including the motor , the frame the glass . Then just pull on it tell it pops out .
Old Mar 11, 2003 | 01:59 PM
Mine is the manual mirror with the remote switch on the door panel. Dont you remove the four screws from behind the mirror glass itself, then remove the little handle part from the cord and then pull it thru? The hole is very small. I want to keep the mirror housing in place so that I wont have to repaint.
Old Mar 9, 2014 | 09:03 AM
tom84z28's Avatar
Car: 1984 Camaro Z-28
Engine: 305 HO
Transmission: Automatic
Re: How to remove side view mirror glass?
The shop manual for my '84 Z28 has a diagram showing a manual mirror, a remote control mirror operated by a lever, and an electric remote mirror. Under that diagram in a section entitled "Remote Mirror Face Replacement" it says the glass in the remote mirror face is replaced by breaking it. It instructs you to wear the appropriate safety equipment (gloves, eye protection, etc.) and cover the mirror housing and surrounding painted areas (like the door) to avoid damaging the paint. Next you cover the mirror face with tape and break it. Remove the broken glass and fiber pad from the frame, then clean out the frame so the new mirror will stick. To install the new mirror, remove the paper backing to expose the adhesive, center the mirror in the frame and press it on. The section does not specifically address electric mirrors or manual mirrors as something to be handled differently.
Old Apr 12, 2015 | 03:06 PM
levy's Avatar
Car: chevy camaro
Engine: 350 LT1
Axle/Gears: 3,42
Hi
Searching the web for my answer I found that only one possibility is to brake the glass then replace it with new one. It would take me a long time to get this glasses because I had to order it to Poland so I try to take it without breaking it.
There is a solution
Old Apr 17, 2017 | 05:15 PM
JRobling's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
Old Apr 17, 2017 | 06:30 PM
NoEmissions84TA's Avatar
Try either heat or cold. If the entire assy is off the car, stick it in the freezer for a while. Then see if the glass will pop out.
For heat, use a hair dryer or heat gun. But be careful if using the heat gun. Before you can say, OH ****!, you have already melted something.
Old Apr 17, 2017 | 08:44 PM
Drew's Avatar
It'd sure be nice if someone didn't reanimate half a dozen dead threads to advertise their Youtube channel. I can appreciate the effort that goes into making an instructional video, but wouldn't it just be easier to create a new thread and post all the video links there?
The problem with bumping old threads, is it puts them at the top of the forum, shoving threads where people are asking for help with problems they're having NOW down the page, in favor of threads people have long forgotten about. Then the thread gets even more replies because most people don't read the ENTIRE thread before trying to help out... So no one really sees your link, and it screws over everyone else on the forum.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
BrianI
Aug 9, 2015 11:52 AM
3rdgenparts
Aug 8, 2015 07:09 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
