View Poll Results: Should I clear Coat my IROC rims?
Yes Clear Coat them
33.33%
No, just keep them maintaned
66.67%
Voters: 6. You may not vote on this poll
To clear coat or not.. That is the question!
Old Mar 11, 2003 | 06:44 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Just finished my third '86 IROC rim. I have sanded, sworn, cut myself and stood back in a amazement of what can be achieved. Should I now clear coat or leave as is? I appreciate some work will be required to maintain without...
Old Mar 11, 2003 | 07:19 AM
97-1LE's Avatar
Car: 87 Trans Am
Engine: Built 350 Cam, Headers
Transmission: 5 speed
I asked the same question a few weeks ago when I started doing my IROC wheels. Most everyone says do not clear coat because it wil stat to yellow after a period of time. Just polish them every few months.
Old Mar 11, 2003 | 07:30 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I wonder if it would even stick well to the smooth surface? Probably better to just to polish them regularly. Would be good idea though if it didnt take away to much shine. And you could get a hard coating like the OEM did.
Old Mar 11, 2003 | 08:48 AM
transam305's Avatar
Car: 1989 White Trans-AM
Engine: 305 TPI hopefully Upgraded Soon.
Transmission: Crappy Needs Improvment.
no clear coat.... keep polished clear coat bad... lol sorry i wouldn't clear coat them i hate painted rims i like the look of nicely polished chrome rims they look vary nice...
Old Mar 11, 2003 | 10:21 AM
Jza's Avatar
Jza
Clear coat may detract from your hard-earned luster.
You can keep it pretty nice by waxing them regularly, and keeping them as clean as possible. Letting brake dust build up then get wet causes an acidic buildup (according to Fikse, a maker of high-end competition wheels). They recommend cleaning regularly with a 50/50 mix of Simple Green (a non-caustic degreaser, unlike the purple varieties which etch aluminum) and water and a camelhair paintbrush [sable?]. If you've been keeping it waxed everything should just fall off the rim. The wax will also prevent oxidation and other aging effects.
Look here for their complete Wheel Care Tip Sheet.
Old Mar 11, 2003 | 11:26 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Jza..Thanks for that link!
Old Mar 13, 2003 | 02:40 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
No clear.
Frozer!!!
Jan 19, 2024 04:55 PM
diana227vegas
Jul 8, 2016 12:27 AM
Scamo-2.8
May 20, 2016 07:01 PM
deracer
Apr 11, 2016 12:04 AM
