Wheel wells.
Old Mar 19, 2003 | 02:24 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Wheel wells.
Whats the best stuff to use to make them blakc again?
Rattle can por 15 etc...?
Old Mar 19, 2003 | 02:26 PM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
I actually painted mine flat black. I went and bought some sot of "RUST PAINT" that was flat black. I figured that would last in the wheel wells. I must say with the wheel wells all black again, it does make the car look 100x better, not like before when there was permanent brown mud in some spots.
I first cleared the wheel wells with varsol until they were pretty much black, then painted about 2 layers, with the wheel wells all taped up.
Old Mar 19, 2003 | 02:30 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Ill bet that stuff they paint the heaters that go in the chimney of houses would do a terific job and it would last a long time. I think it is called stove black.
Old Mar 20, 2003 | 03:36 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I removed the plastic inner fenders and hit them with a rattle can after cleaning them.
Old Mar 20, 2003 | 03:47 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
I used 3&M undercoating on mine....left a rough surface so nothing really sticks to them, the water does stick, doesnt fade so far......and also left a shiny finish. Hope this helps.
Old Mar 20, 2003 | 04:50 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Hit mine with Duplicolors sound eliminator and then with semi gloss black. Gloss was unnatural looking, but flat too dull! Made a big difference.
Old Mar 20, 2003 | 09:09 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
I'm using undercoating on mine also. I took them off, cleaned them, and sprayed a few coats of undercoat on, they'll go back on when the new paint goes on the car.
Old Mar 21, 2003 | 09:24 AM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
i took the pressure washer to them. let them dry.......then jacked up the car and hit each one with "Rubberized Black Undercoating"......works good!
Old Mar 21, 2003 | 10:30 AM
ezekielta's Avatar
I use flat black and then when I show it I hit them with some tire shine to make them look really pretty.
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
