Sanding Paint
Old Mar 21, 2003 | 12:39 AM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
Sanding Paint
i used search but found nothing really helpful.
so my question is what steps, grits, etc, i want to take out the orange peal in my paint on my bird, what do i have to do, wet sanding, dry, what grits, steps. etc, what all do i need to do to get rid of it. thanks for any help.
Old Mar 22, 2003 | 01:22 AM
Squeeks83's Avatar
so what no one has ever done their own body work, or sanded their paint, or what, this sucks.
i just wanted to know the grits i needed.
Old Mar 22, 2003 | 09:28 AM
camaro6spd's Avatar
Ok this is how i did it...i personally did it this way, i had 2 coats of clear on and i did burn through in one small spot but it did not matter b/c this was a fender that i was experimenting with(first time ever painting and buffing and ****).
Wetsand using a softblock with 1200 grit to get rid of the majority of defects, then go to 2000 grit. After you wet sand it down then buff the car out using a buffing machine and I did it like this
3M HeavyCut Compound
3M MediumCut Compund
Machine Glaze
Hand Glaze
It came out like a ****ing mirror, it was as smooth as glass when you touched it.....I am am painting my car now and I plan on laying extra coats of clear so i can sand out all the defects and then buff.
Old Mar 22, 2003 | 10:34 AM
Squeeks83's Avatar
ok thanks thats all i wanted to know, im sanding her now with 400 wet sand to take out some junk, then im going to put on a new fender and front bumper then shoot some jet black on her then do this sanding. thanks for the info and good luck.
Old Mar 22, 2003 | 06:18 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
at my work (body shop) i do 1500 with the D/A sander (dry). they i use the D/A with 2000 (wet). after that i buff it with medium cut compound, followed by machine glaze, then topped off with hand glaze. the results are amazing.
Old Mar 22, 2003 | 11:08 PM
missKittys86's Avatar
from skratch?
Well, suppose you are lucky enough to own an 86 out of Van Nuys, almost everytrhing is still original stock. My baby needs lots of TLC. What do I do with a car that has a thick black primer, done by an inexperienced teen age car abuser? I mean it looks bad, it's chipping, fading in spots, over primed in other areas, and what this kid did to the door, oh. Where do I start???
HELP PLEEZE
Old Mar 23, 2003 | 07:18 AM
ninjairoc's Avatar
Car: 1986 Camaro IROC-Z
I also have the unfortunate van nuys paint job that has faded off
Old Mar 23, 2003 | 07:49 AM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Hand sand the entire car with 80 grit. I began sanding my car with 80 grit only to realize there was 2 different paint jobs on it before. So I took it down to the original primer, it took some time but it was well worth it.
Old Mar 23, 2003 | 08:05 AM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Wow, you're a glutton for punishment. For $30 you can get a cheap D/A sander and do it in 1/10th of the time and save the 4 blisters on your hand.
By the way, 82firebird, any progress pics? I've been keeping up with your paint project since I'm doing the paint/bodywork on my 83.
Old Mar 23, 2003 | 11:13 AM
Squeeks83's Avatar
i have a car paint store in the next city, now what stuff do you reccomend i go and get, i want to do all my own body work. and what i want to do is sand down the car, and have soemthing to buff the car with once i get paitn on her. so like an orbital buffer. but how much does this stuff cost and what are the names for the componuds?
Old Mar 23, 2003 | 11:57 AM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
I've been pretty busy with track starting up, but I have made some progress in the last few weeks. I hope to spray the primer within the next few weeks. I updated my cardomain site on page 9..
http://www.cardomain.com/member_page...=242913&page=9
Old Mar 23, 2003 | 03:31 PM
Car: 84 camaro Z28
Engine: 434sbc
you need to get sand paper and body filler. its also good to have a grinder, D/A sander, buffer, stuff like that. as for the polish, i you all 3M stuff:
perfect it III compound (use a stiff white foam pad for this)
perfect it III machine glaze (use a black foam pad from this)
hand glase
i will grab some pics of my supplies tomorrow for you.
also if this is you first time, then i would put a minimum of 3 coats of clear over the paint. just to be safe
Old Mar 23, 2003 | 11:17 PM
Squeeks83's Avatar
ive painted cars and such before but never did anything after that, i mean ive always hand sanded it all, took for ever and anoyed the hell out of me, but i was going to shoot jet black with probally a silver or red metallic flake, then put about 5 cloats of clear on it, make the ****er shine.
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Sep 21, 2015 08:54 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
