started polishing
Old Apr 2, 2003 | 01:41 AM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
started polishing
well tonight i started some polishing on my runners, and a little more on the plenum, all this stuff done to the plenum was done by the prevous owner. when im done it should, i hope, look like its all been tripple cromed.
everything you see i sanded only with 180 so far, the left side also. thats all i have gotton done so far, but tomarrow i go and get the buffing wheels and compounds so after im done sanding i gat to ahve soem fun polishing.
Old Apr 2, 2003 | 01:46 AM
Squeeks83's Avatar
last one, josh, screaminformula, did this before i bought it, did a good job but nothing compared to waht its going to be.
Old Apr 2, 2003 | 01:59 AM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
well, Shean, ya got a LOT ahead of ya, trust me. i worked with that plenum about 6 hours just to get that crappy (by most standards) finish. but good luck and maybe you will get it lookin better than i did since you have it off and i didn't. go look in the Tech section here and find out the proper procedure to do it, thats what i did...
good luck with her Shean!
Josh
Old Apr 3, 2003 | 12:16 AM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
Lookin good! Ya gonna do mine next? jk. By the way ill take that butterfly knife you have there on your desk, lol
Old Apr 3, 2003 | 12:29 AM
joshp14's Avatar
dont forget to buy the aluminum plenum extension if you havent already...
Old Apr 3, 2003 | 12:30 AM
joshp14's Avatar
Old Apr 3, 2003 | 12:40 AM
no, Kyle, no cutting in line, IM NEXT ASSHAT!!! just kiddin man! wait, no SHEAN, YOU KEEP SANDIN, YOU AIN'T GOT NO TIME TO AROUND!!!!
Josh
Old Apr 3, 2003 | 09:09 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Just go through the steps of different grits and use some different compounds. It'll come out niiiice
Old Apr 3, 2003 | 11:06 AM
CDN_87IROC's Avatar
Or pay to have it done
Old Apr 3, 2003 | 12:19 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
How much did that cost and where did you get it done? There are a couple pieces on my buddies boat that we want done but cant find a good place to do it.
Brian
Old Apr 3, 2003 | 02:45 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
how many hours have you spent working on it so far?
Old Apr 3, 2003 | 03:27 PM
Squeeks83's Avatar
well so far ive doen about 2.5 to 3 hours of sanding by hand with 150 grit. but then i retro fitted soem sand paper to the dremel and it took like 10 minutes to do the rest of the runners and plenum. today i start the wet sanding with 320, then 400.
i picked up yesterday 3 hard sanding wheels and 2 soft. im going 1 hard emery, 1 hard tropoli, 1 soft tropoli, one hard white rouge, then last 1 soft white rouge and they should turn out very nice.
kyle, if you want ill do this for you but i dont do it in your engine bay. you pull your TPI and ill do it for $50.
Old Apr 3, 2003 | 09:47 PM
A88GTANotchback's Avatar
When u did it on ur motor did u have alot of sanding dust left all over ur motor? i wanna do it this way but dont wanna make to much of a mess. i just finished two rims and am very happy with the results
Old Apr 3, 2003 | 09:51 PM
Engine: 5.7
Yeah, that was the bad part...but.....after doing it..I just used a leave blower...300+ winds....got EVERYTHING perfectly clean :O)
Old Apr 5, 2003 | 04:18 PM
sweet ill just crack out the big ole air compressor that fix her.
Old Apr 5, 2003 | 07:53 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
I know he isnt polishing rims, but when i started doin mine the clearcoat was really really hard to get off..so much as i had to etch it off the center of the rims w/a screwdriver..is that normal?
Old Apr 5, 2003 | 07:56 PM
Engine: 5.7
Did you use any kind of chemical stripper?
Old Apr 6, 2003 | 12:19 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
no i didnt cuz i read in a post somewhere that it ruins the rims
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
86IROC112
Sep 29, 2015 04:07 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
kah992
Aug 19, 2015 02:55 PM
