how do i get humidity out of my tailights?
Old Apr 28, 2003 | 11:47 PM
19WS6T/A91's Avatar
how do i get moisture out of my tailights?
im just wondering how am i supposed to get the humidity out of the tailights.you can kind of see it in the pic, its all were is says pontiac in the middle.
Old Apr 29, 2003 | 12:12 AM
Kaps's Avatar
Looking at my broken center section right now(damn stereo thieves!). Take it off bring it inside to dry, then try resealing it with some sort of glue, on mine looks like the bottom isnt sealed all the way. I think ATV with a THIN bead might do the trick, just make sure that the waters all out before you seal it.
BTW, anyone have an extra center section looking to get rid of PM me
Old May 1, 2003 | 10:52 PM
19WS6T/A91's Avatar
is there any way to take the light apart where i could dry the moisture with a rag then seal it from the inside?
Old May 1, 2003 | 11:49 PM
deadtrend1's Avatar
take then off, switch tail lights with me. Ill see if i can fix those but they seem to be pretty far gone!
but anways is the water leaking in from the light socket or somewhere else in it?
Old May 2, 2003 | 01:08 AM
Kaps's Avatar
Wow, I didnt realize you had the diff lights on your car. I guess you could probally seperate em, never seen those kind off the car, so I dont know for sure. I believe redraif took apart her taillights and succesfully got them back together, but she had the normal ones. Arent those rare, or at least hard to find used to buy
Best bet, take em off the car totally, fill them with water, if no water leaks out, then you have to make the connection around the light sockets tighter, try some rubber gasket material, wouldnt use liquid crap on the sockets, might make it messy/pain to change the bulbs when need be.
Good luck
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
92GTA
Apr 9, 2016 07:39 AM
90formulaVortec
Sep 7, 2015 06:54 PM
GregWestphal
Apr 9, 2001 11:00 PM
