just vhted my rear tails
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
it looks good on the one i did but the one my friend did u can see the runs. also its a bitch to get the reflector out so i left the drivers on but the pass got out so i painted the lens and the reflector. if u paint the reflector and not the lens its not as dark
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
You might be able to wetsand the runs out, and then respray another coat. Got any pics?
Car: 1989 IROC-Z
Engine: 383 stroker
Do a search, you'll find a bunch of posts detailing it.
Or you can use the attach file feature to attach pictures from your computer.
give me ur email and ill send them to u
i also did my turn signals and they look ok but i had to do it on the outside
ok i will
u happy metal
ok i will
u happy metal
Car: 1989 IROC-Z
Engine: 383 stroker
You can post them, click the "Browse..." button above the "Submit Reply" button. Then find the file. One or two will suffice, you don't need to go posting all the pictures you have on your PC. If you want to show off a bunch, I suggest making a webpage and uploading them there. Try www.cardomain.com for that.
Edit- I'm so proud
You found the edit button
Edit- I'm so proud
You found the edit button Last edited by MetalliCamaroRS; Apr 30, 2003 at 01:07 AM.
ambainb
Apr 25, 2016 09:21 PM
theshackle
Aug 23, 2015 03:49 PM
