Stripe Dimensions Needed
Old Apr 30, 2003 | 09:02 PM
steve88iroc's Avatar
Car: 1988 IROC-Z
Transmission: WC T5
I am in the process of having my 88 IROC repainted and I need some info on the lower stripes. When I bought the car in 97 the owner had removed the lower stripes, and now that the car is being repainted I would like to put the stripes back on. My problem is that I need to know how wide each of the colored stripes are supposed to be, and how wide the gap of body colour is between the two stripes. Any info would be appreciated.
Old Apr 30, 2003 | 09:14 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
You're painting them back on? Mine are stickers, you could probably find the sticker set somewhere.
Old Apr 30, 2003 | 09:21 PM
Car: 1988 IROC-Z
Transmission: WC T5
Maybe I wasn't clear....no I am not painting the stripes on. I am having a sign shop cut them for me and that is why I need the dimensions. I've already looked into kits, and by the time I pay for the stripes and the shipping (plus dealing with customs) to Canada it would have been cheaper to have the stripes made here.
Old Apr 30, 2003 | 10:51 PM
Abubaca's Avatar
I work for a sign shop, and I cut my own stripes!!!!
My top/black stripe is 11/16" and the bottom gold/silver stripe is 3/8". I've re-striped my car twice, and I always eye-ball the dimensions, so I'm pretty sure that's not exactly factory, but depending on how good your eye is, I'd bet most would never know the difference. I don't actually know what factory spec is.
Hope it helps.
Keep in mind since a sign shop will cut these out of seperate rolls of vinyl, you'll have to apply each stripe seperately, which is more difficult. No big deal, but it requires more patience. I have a friend who runs a garage, so I put it on a lift. This helps TONS. It's a pain without it, since the 2 stripes are going on seperately, and they're hard to apply evenly.
Did that make sense?
Old May 1, 2003 | 10:10 AM
Car: 1988 IROC-Z
Transmission: WC T5
Cool....how much of a gap do you leave between the stripes?
Old May 1, 2003 | 06:53 PM
Abubaca's Avatar
I normally put down 2 gold stripes. The one on the bottom is permanent. I use the second one as a spacer to make sure the I keep an even gap. Of course, I have the luxury of cutting extra striping at no extra charge. Once the black stripe is down, I just remove the middle stripe, and the gap is perfect.
Old May 3, 2003 | 06:38 AM
Car: 1988 IROC-Z
Transmission: WC T5
thanks for the help....much appreciated.
Old Mar 5, 2004 | 10:33 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
space???
Aubaca you said you have a space between the stripes,i was planning on putting down the gold and overlapping top edge with the black,is it the difficulty of keeping the overlap the problem?also how about the door decal placement??
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
drathaar907
Aug 10, 2015 07:44 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
