Crumbling paint?
Old May 5, 2003 | 05:48 PM
GoonieZ28's Avatar
Car: 91 Z28
Engine: 5.7 TPI
Transmission: ProBuilt 700-R4 & Vigilante Torque Converter
Crumbling paint?
I'll be getting a paint job soon... but I have a question.
Do you guys recommend taking off the side molding to get it painted underneath, then paint the molding? If so, can you re-attach the molding with some kind of adhesive?
Also, if they just paint over the molding... would the paint dry in between the door and the molding (right on top of the molding for example), so if I push on the paint there, in the crack, would it cruble? Anyone know what I'm talking about?
What did you guys/girls do when you painted your car?
Thanks!
Old May 5, 2003 | 06:11 PM
Irhal's Avatar
Car: 94 Firebird
Engine: 3.4L
Transmission: t5
the paint won't make a bridge from the molding to the door... will it show that you didn't take it off? no, but it'll be a PITA for further work on the door... My suggestion is to take it off so you can paint both separetly... and yes alot of companies sell adhesif for that kind of molding... I always use 3M though... but that is just a personal habbit
Old May 5, 2003 | 10:10 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
That depends on the thickness of the new primer/paint/clearcoat. There's a good chance that it will be obvious that you didn't take the moldings off.
I read in a post a while back about taking dental floss and "sawing" the adhesive to get the moldings off. From there you just use adhesive remover on the door and the trim and once the car is painted, use 3M adhesive to stick them back on.
But once you take them off, you won't want to put them back on because it will look so much better without them.
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Sep 21, 2015 08:54 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
