Decal removal question....
Old Jun 1, 2003 | 10:58 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
im getting some original style decals for my formula cause the ones on the car are not the original style font. What would be the best way to get the old ones off the car. Ive heard some people say that they've taken a hair dryer to the decal.....heated it up and then just took it off with there fingernail. any info would help...thanks.
Old Jun 1, 2003 | 11:05 PM
jgifford's Avatar
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
I always used a heat gun to pull off bumper stickers, it works as long you don't keep heat on too long.
Old Jun 1, 2003 | 11:10 PM
TorchRay's Avatar
Car: 89 WS6 Formula
yeah someone told me that too.....but just not to hold the heat on the paint very long.
Old Jun 2, 2003 | 02:57 PM
TorchRay's Avatar
Car: 89 WS6 Formula
any other info at all would help.
Old Jun 2, 2003 | 04:05 PM
jgifford's Avatar
Car: 1986 Z28
Here's what I'd do...
1. Use a heat gun to loosen up the adhesive, be carefull and do it in small sections. This should take the most if not all of the adhesive off.
2. While it is still kind of gummy, use a wash rag and hot water, and gently rub the what's left over. It ought to roll up and come off.
3. Then go wash your car so you'll have a clean surface to stick the new ones on.]
4. Finally, Put those bad boys on...
Old Jun 2, 2003 | 04:58 PM
patrickm00's Avatar
3M also makes a real good spray that will help get leftover stuff like adhesive off. they sell it at walmart, kmart, auto stores, etc. i don't have the exact name, but it's an auto adhesive remover. it doesn't hurt paint that's cured (anything over a year should be fine), and is clearcoat safe. i used it to help get my tacky, dealer-installed pinstripe off. i also used a flat razor blade, with tape on the ends (raises it up, and keeps you from cutting into paint) to take most of the decal off.
but definitely use some heat.
Old Jun 2, 2003 | 07:45 PM
T3am Z28's Avatar
I used 3M Adhesive Cleaner.. worked pretty well..
-LJ
Old Jun 3, 2003 | 12:34 AM
TorchRay's Avatar
Car: 89 WS6 Formula
awsome...thanks everyone. Ill be sure to put up a pic...and the progress once its done. Thanks again.
Old Jun 5, 2003 | 12:10 AM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
3M makes a glue buster thats fits on a drill it will take off all of the decal and glue and leave a clean finsh
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Stroopwafel
Sep 11, 2015 06:38 AM
pimprs
Sep 10, 2015 03:34 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
