Question on aircraft strippper?
Old Jun 13, 2003 | 01:41 PM
pmurray3's Avatar
I am stripping my rims I have the 15 inch RS style. The type of 5 stars that bend in and are not flat like the Iroc style. The type that the rims are painted to match your car's color(i.e. red car red rims) Should the stripper remove the clear coat and the paint? I have applied a few coats and have gotten the clear coat off but they still look gray like they always have. Do i just sand the paint off from here or should the stripper remove some or all of it?
Old Jun 13, 2003 | 02:04 PM
89FRMLA350's Avatar
Engine: None
Transmission: None
It should start removing the paint. It's also good to use those green scrub pads from ACE Hardware to help remove the paint and clearcoat.
Old Jun 13, 2003 | 02:57 PM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
i used the stripper on my crosslace rims.... and they took off everything including paint and clear coat in one treatment..... try globbing on the stuff.
Old Jun 13, 2003 | 03:21 PM
pmurray3's Avatar
I bought the damn spray kind because they were out of the bottle kind. Damn maybe thats the problem. I heard the spray kind isn't as good. Thanks guys.
Old Jun 13, 2003 | 04:15 PM
SC82TA's Avatar
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
I've used the spray kind...just make sure you have a nice thick even coating and let it sit for a good 20min. Afterwards it should all come off pretty easily, the key is to let it sit a while.
Old Jun 13, 2003 | 04:25 PM
BTS88IROC's Avatar
Just let it sit for awhile like the others have said. And from my experience the spray stuff doesn't work quite as well as the other stuff that you would just brush on.
Old Jun 13, 2003 | 08:48 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
DON'T GET ANY OF THAT STUFF ON YOUR SKIN!!!! Not that I would know anything about that *cough*
Old Jun 13, 2003 | 10:27 PM
LeftTurn1LE's Avatar
No store bought chemicals will remove the paint. This picture was taken after several tries to strip the paint from my wheels. You can see that all of the faded pink paint is still there. I have even taken my wheels to a very reputable body shop to be stripped, and nothing they had would take off the paint. The wheels will have to be media blasted or acid dipped, unless you want to go at it with some 80 grit sand paper. Good luck.
Old Jun 14, 2003 | 12:03 AM
trans87's Avatar
Have you tried the aircraft paint remover? I haven't see paint that it couldn't remove yet. The stuff is amazing.
Old Jun 14, 2003 | 10:25 AM
Dingley's Avatar
Engine: LG4 305
haha... yea... that stuff burns, and the burning doesn't go away until you put it under water..... not that i would know anything about that either but anyways... that aircraft stripper takes off about anything... including skin...
Old Jun 14, 2003 | 10:34 AM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
I used aircraft stripper on my '88 IROC rims. Worked fairly well.
Old Jun 14, 2003 | 02:48 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
A.R. worked great for me too.Some spots needed to be repeated sometimes with a small soft wired brush or scouring pad but all of the paint came right off my wheels.
3 things not to get that stuff on are plastic,tires(turns affected areas brown) and as someone had said DO NOT!!! get that stuff on your skin!
yeeeoooooowww!!!!!
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
