Home made clear coat removal
Old Jul 24, 2003 | 12:21 AM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Does anyone here know of a home made method with stuff laying around that will remove clear coat from aluminum? I did a search and all I got was products to buy.
Old Jul 24, 2003 | 12:32 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Why not just buy stuff, its only like $5-$7.
I don't know if it'll work, but you can try brake fluid
Old Jul 24, 2003 | 12:49 AM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
Metalli, you shouldn't mod the boards so late at night, you say the craziest shiet...
Old Jul 24, 2003 | 12:51 AM
shaggy56's Avatar
Car: 71 Nova
Well reason I asked I considered using oven cleaner but didnt know if it would damage the aluminum.
Old Jul 24, 2003 | 03:54 AM
Midnight Sun's Avatar
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
MOONSHINE!
No, just spend the money to get the proper stuff. Trust me, when you try to do things to be cheap, you end up doing more damage which will cost you more money in the end.
Screwing up the little things to stay cheap is really a PITA.
Old Jul 24, 2003 | 08:45 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Oven cleaner will remove annodizing from aluminum, but I doubt it would work on clearcoat. If your clearcoat doesn't look good though, try it, what have you got to lose?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
