Buffing T-Tops/Tail Lights/ and what not
Old Aug 24, 2003 | 11:39 PM
1989TransAm's Avatar
I would like to clear up my T-Tops so they have a beautiful mirror like finish, I've been browsing around and seen many different steps that people took to do their Ts and Tail Lights....however I do not have a buffing wheel, and would like to purchase a good one that I can use for all my car care needs including glazing & waxing...so my questions for you are...
What is a good orbital buffer that I should invest in for the long run? I heard Makita is excellent?
Is it safe for me to use to apply and buff wax off the car, as well as glaze it? (I'll save the compounding to the professionals.) Can I "burn" the car by using the buffer?
What are the steps for me to take to make my T-Tops beautiful? (I believe they are made my a company called Lexamar.)
What are the steps for me to take to make my Tail Lights beautiful?
And finally...can these things be done without screwing anything up if I'm careful, and don't use the buffing wheel at a high speed?
Thank you for any help and advice you may provide.
Old Aug 25, 2003 | 06:42 AM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
Here You go:
https://www.thirdgen.org/techbb2/sho...hreadid=197964
Old Aug 25, 2003 | 10:11 AM
how about doing the t-tops?
will i screw something up?
what steps do i need to take wetsanding the t-tops?
do i soak the sandpaper overnight?
how many different grits do i use?
how do i know when to stop sanding using a certain grit?
AHHH all the questions!
is it okay to just glaze and wax using the wheel without damaging the paint?
Old Aug 25, 2003 | 10:16 AM
EYEROCK89's Avatar
Car: 1989 IROC
Well, If I were you, assuming you don't get any help from your thread...I'd call an auto glass shop and ask them. They will know of something. I'll look around and see what I can;t find out for you.
Old Aug 25, 2003 | 10:20 AM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Do you have the Lexan Ttops?
I would probably start sanding at 1000 wet, then 1500 wet, then 2000 wet. You just bring a bucket of water with you and dip the paper in it, then start sanding.
I would like to see some insight from those who have wetsanded and polished their Ttops though, incase I am wrong.
Hawk312
Aug 22, 2017 08:55 PM
starliner
Feb 9, 2016 08:18 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Gta-Paladin
May 15, 2002 11:28 PM
