how to get rubberized coating out of fender wells?
Old Sep 7, 2003 | 09:21 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
how should i go about gettin the rubberized coating out of my rear wheel wells. i have a lot of rust forming behind some of the rubbercoating so i need to get it all out and sand blast the entire well then use some type of bed liner in there.
Old Sep 7, 2003 | 09:27 PM
Briansz28's Avatar
I had to fix some spots of rust there too. I used a paint scraper to get the big chunks off, wire brush (cup type) on a drill to get more off and then scubbed it with a rag soaked in mineral spirits. I then pop-rivited a patch in and sealed it withe POR15 patch. I want to do the rest of the inner fenders but will probably wait til winter.
I had a fuel line let go near the tank and the gas did a great job removing the undrcoating too-
Old Sep 7, 2003 | 09:36 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
ill give that a shot. i thought of sand blasting it off? i have a sand blaster if that will work i might as well try it i guess. anyone know?
Old Sep 8, 2003 | 09:55 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
You sure it's not melted tire
Old Sep 8, 2003 | 10:13 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Heat it with a propane bottle and do a bit of scraping.
JamesC
Old Sep 8, 2003 | 02:00 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
theres quite a bit of that in there to, crack sealer burnouts make a big mess.
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
skip91
Sep 24, 2015 03:29 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Warlocksirix
Sep 3, 2015 12:26 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
