wheel spacers?
Old Sep 30, 2003 | 12:22 PM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
wheel spacers?
i got a set of used iroc wheels cheap and want to put the, on my 87 v6 camaro but all four are rears. i was under the impression i would be able to do this on a drum rear car but apparently not.
does anyone know where i can get cheap 1/2" wheel spacers and studs for the front that are 1/2" longer than stock?
Old Sep 30, 2003 | 12:54 PM
82camaro's Avatar
Car: 82 camaro SC
You need all 4 fronts--4 front wheels will work on any thirdgen. To do it right, you need to get a set of adapters. The adapter bolts to the hub, and the wheel bolts to the adapter. It's the only way to do is safely, IMO. However, cost wise, it may be cheaper to just get a set of fronts.
Old Sep 30, 2003 | 01:45 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
What he said.
Old Sep 30, 2003 | 10:30 PM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
rear irocs may or may not rub on the front of the car. And if they do, you can most likely get away with slip-fit type spacers that are a little under 1/4" thick.
I've seen cars where 16" rear rims did not rub on the front without a spacer, and i've seen cars where it did. Either way, it's gonna be close, but the tiniest bit of clearance with a slip fit spacer should do the job.
btw, i do not recommend using slip fit spacers that are 1/4" thick or thicker. And even with less than 1/4" make sure you are getting a LOT of thread from the studs into the lugnuts. Also, i do not believe they would be nhra legal either. just fyi.
and for the record, 4 fronts definitely look the best
Old Oct 1, 2003 | 10:22 PM
Axle/Gears: 4.10
yea, i know 4 fronts look best but thats really not an option right now. but back to the question i asked, does anyone know where i can get studs that are 1/2"longer than stock? im going to make the spacers in a machine shop
JB82Z-28
Exterior Parts Wanted
Oct 6, 2015 09:05 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Fionnla
Wheels and Tires
Sep 11, 2015 11:07 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
