shaved front end to fenders
Old Sep 27, 2003 | 05:37 AM
brobert's Avatar
I was fixing a small dent in my rear by my tail lite and when i was done i looked at the front of the car and got an idea, you know the small space between the front end nose and the fenders? I was thinking of how smooth the car ( firebird ) would look with that space filled, sanded and painted to match the car. I know if you ever needed to change the front end it would make it harder but i think it would look cool. Does anyone know what im talking about? :lala:
Old Sep 27, 2003 | 10:23 AM
icebird_1981's Avatar
ya i was gunna do this to my firebird with the noes and the bumper and the fender vents. yes it would look alot better i think.
Old Sep 27, 2003 | 11:20 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
scauffiel tried that on his whole car and it kept cracking because it moves and flexes so much, so I don't think its possible.
Old Sep 27, 2003 | 12:28 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
well, if you bonded the 2 parts from behind, and then used a flexible plastic filler, that might work. somthing like what you use to repair the tears in the nose.
Old Sep 27, 2003 | 12:31 PM
Car: 1989 IROC-Z
Engine: 383 stroker
I still think it would flex and crack. I don't know the method scauffiel used, but I know he tried for a while and nothing worked.
Old Sep 27, 2003 | 02:26 PM
brobert's Avatar
What about fiberglass underlays then filler? I did it to my rear bumper and so far its been ok and i only used bondo. Takes alot of sanding to get the shape right. But when its done it makes the car look so smooth.
Old Sep 28, 2003 | 12:46 AM
FLYNLOW92rs's Avatar
TribalDaze pulled it off.....
Old Sep 28, 2003 | 12:50 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
uhh, i think you posted that in the wrong thread... this is the shave the nose to the fenders thread, not the shave the holes off the GFX thread...
Old Sep 28, 2003 | 10:41 AM
Drone's Avatar
Car: 97
Engine: 3800 v6
Transmission: AUTO
uh dood....look again...that car is what your talking about...its seemless from the nose to the fender. the vertical line is gone. there are better pictures of his car.
i actually asked this question before and flyinglow posted a better picture of his car.
Old Sep 28, 2003 | 02:09 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
uhh, im looking where the nose attaches to the front fender... i still see a line.
the only smoothed thing i see on what he posted is the GFX.
Old Sep 28, 2003 | 04:21 PM
brobert's Avatar
yep the line is still there
Old Sep 28, 2003 | 11:07 PM
Drone's Avatar
Car: 97
Engine: 3800 v6
Transmission: AUTO
your both wrong and ill prove it.
Old Sep 28, 2003 | 11:14 PM
Drone's Avatar
Car: 97
Engine: 3800 v6
Transmission: AUTO
there.....still see a line?!
Old Sep 28, 2003 | 11:24 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
im convinced he just accidently posted the wrong pic, or the right pic in the wrong thread.. when he posted that, we were talking about smoothing the GFX in another thread.... but if you wannt be a hard head.......
Old Sep 28, 2003 | 11:25 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
yup. i still see the seam mark.
from the pic i posted, you can see it clearly... from the other the top looks smoothed, but you can still see the line...
Old Sep 29, 2003 | 12:35 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
i wouldnt bother with it really. i honestly HATE body filler. i like true straight metal. my car got hit in july so my dad and i are doing body work. i totally stress on him i want hardly any filler and so far the extra work to get the metal as straight is can get has worked off. if u wanna shave somethin do the antena, im doin mine just for kicks.
Old Sep 29, 2003 | 01:09 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
coo... im doing my antenna, door handles and gas cap
Old Sep 29, 2003 | 06:26 AM
brobert's Avatar
Friend of mine did his ant. Now he gets hardly any stations. Does look alot better without the big whip sticking out of the car.
Old Sep 29, 2003 | 12:45 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
there are several things he could do to solve that..
a better hidden antenna, and a signal amp should probly solve that for him.
Old Sep 29, 2003 | 01:15 PM
Mine is in my passenger side fender......a little bent, but it's there.......
Old Sep 29, 2003 | 07:42 PM
Drone's Avatar
Car: 97
Engine: 3800 v6
Transmission: AUTO
yes we are talking about the same line.....and it is smoothed....its not perfect but its done. just look at the pic i posted...you cant see a line, all you can see is where the difference between the metal and plastic make the paint look a little different. and the line in your pic, im convinced its just some photo flaw or sumtin, and its barely visable....the angle of it makes no sense for it to be the line. but either way....the photo quality isnt good enough to prove it one way or another.
Old Sep 29, 2003 | 08:04 PM
brobert's Avatar
Ok then shaving the fron end to the fenders can be done without cracks. correct?
Old Sep 29, 2003 | 08:22 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
eh, it was smoothed... but jsut not very well.. :shrug:
i donno if its from the flexing or the prep work... but if it comes out like that, i wouldnt do it.
Old Sep 29, 2003 | 09:36 PM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
ive done it (well not actually me but the body shop) i have had to go back many times to get it fixed... but it does look cleaner..
iroc2nv
Old Sep 30, 2003 | 06:31 AM
brobert's Avatar
I guess ill just settle with my rear bumper and maybe my ant.
Old Sep 30, 2003 | 11:33 AM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
If you had fiberglass front fenders the probability of pulling it off seems greater to me. In fact, using a resin of some sort (not exactly sure how working with glass works), but you may be able to bond the two pieces (even though the front isn't glass). Just a notion. iroc2nv, what kinds of problems have you had?
Old Sep 30, 2003 | 05:48 PM
iroc2nv's Avatar
Axle/Gears: 3.45
actually the only problems that i have/am having is the fact that certain places keep bubbling...i dont know why but its always on the front pass. side and the rear drivers side...
iroc2nv
Old Sep 30, 2003 | 06:55 PM
onebinky's Avatar
I -think- that's just a reflection. If you look on the front GFX piece, it has the line directly below that line you highlighted. The GFX piece doesn't end there, it goes all the way to the wheel well.
I tried doing on my 85 that I had, and it ended up cracking too. I think to successfully do it, you would have to section out about 1/2" between the two panels, put a backing plate behind it, and then fill it with urethane filler so it will remain flexable with the body.
Matt
Old Oct 1, 2003 | 12:10 PM
Fastcamaro87's Avatar
See Picture Above ^^^in his original post
u can clearly see that the line between the nose and the fender is not there anymore. Firebirds dont have a wrap around front spoiler like camaros, they have the spoiler integrated with the front bumper and then 2 small filler peices are on the bottom of the fender to complete the wrap around, (similar to the rear bumper on all thirdgens.
Also the firebird Ground effects dont have holes in them like the Camaro ones do, they mount up differently and are made of urethane Whereas the camaro atleast up until 91 had fiberglass ground effects and mounted in that area u circled , via 2 screws, that the emblem covers. the area that u circled on the ground effect is not modified at all.
Old Oct 1, 2003 | 02:27 PM
stiers's Avatar
The only way to do it properly is with a fiberglass front clip. I have seen one for an early 80s Camaro, but none for a bird or later camaro. The clip works like the viper and the fenders hood and front bumper raise with the hood.
Old Oct 1, 2003 | 10:36 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
I had posted this about a year or 2 ago but..
I wish that I still had the pic but there was a customized 89 Camaro(convertible I think),red and yellow paint,that had all the lines filled/smoothed in from the ground efx to both front and rear bumper covers.It looed pretty sharp except for the 10gal fish tank in the back.
Old Oct 1, 2003 | 10:43 PM
91Zman's Avatar
Car: 1991 Z28
I see the line too on the nose piece,even on the full picture of the car-which you can still see a slight gap/line between the ground effect and the nose part too.
Old Oct 2, 2003 | 12:54 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I agree if you had a whole fiberglass dog house (fenders and front nose) then you could pull it off pretty easily. It's almost impossible to join metal to fiberglass. I installed a set of TA fender louvers in my old 84 Z28 with fiberglass and duraglass. It looked really great but as time went on....it started to have hair line cracks in the filler. Far away, it still looked good, but the closer you got...the better you could see the small hair line cracks. Mostly every panel on any car moves...whether because of temperature or because of bumpy roads....you could try it....but I'm not sure if you would be happy with the results later on down the road. I shaved my antenna on my current car (1991 Z28) I welded up the hole then used some body filler. I try to stay away from applying a ton of bondo anywhere....I had like 2 small dents in my passenger side door I had to fill too.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
madsv1000
Aug 20, 2015 06:45 AM
