nose question
Old Oct 9, 2003 | 09:42 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
nose question
Allright i have to get a new nose for my iroc my two questions are what year did they switch over to the newer style (i believe it was 87?). The second question is okay the ones i currently have now have the fog lights and theres that bit of body that is inbetween the two lights.....i have also seen the nose where it has the grill accross it does that nose still have the piece of body where the two fog lights would be seperated by?? or is it just a big open hole. If it is a big open hole which cars did it come on?
Old Oct 9, 2003 | 09:45 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
By "piece of body" do you mean the piece that holds the license plate? I'm a little confused.
Old Oct 9, 2003 | 03:19 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
srry let me be more clear. Is this thingy on the nose piece that has the grill.....
Old Oct 9, 2003 | 05:01 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
The front bumper cover "nose" is the same for all 85-92 camaros except the 85-87 sportcoupe camaros. The grills are different in some ways but they all use some screws to hold them onto the bumper. The Foglights use bracktes that are attached to the frame or somewhere on the front end IIRC> If I recall correctly.
Old Oct 9, 2003 | 05:26 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
okay what are the 85-87 sport coupe like? Basically what im looking at is i guess cutting that center piece out because im just going to have a big open hole covered with mesh and im going to do some cutting behind it so that i can make a gigantic ram air hole....is cutting that piece out my best bet?
Old Oct 9, 2003 | 09:03 PM
Car: 85 Camaro SC
Engine: V6
This is a 85-87 sportcoupe front bumper, as you can see it cant be used with ground effects
So your basically wanting to cut out the front grille mounting section of the front bumper. I think it will be just fine to do that. You shouldnt have any structrual problems since you will have the front spoiler on there.
Old Oct 9, 2003 | 09:08 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
ahh thats too bad oh well looks like ill just end up doing some cutting on the other one. I'm sure it will look good when its done. Thanks for your help man.
Old Oct 9, 2003 | 09:13 PM
Car: 85 Camaro SC
Engine: V6
No problem, glad to help.
Vintageracer
Jan 10, 2020 05:33 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
neekolzun
Aug 24, 2015 04:59 PM
theshackle
Aug 22, 2015 06:52 PM
redmaroz
Aug 16, 2015 11:40 PM
