Nice trick with TurtleWax Formula 2001
Old Oct 18, 2003 | 05:34 PM
CaysE's Avatar
A friend of mine told me to try this nice trick to get the engine bay looking pretty good in a hurry. Spray everything with TurtleWax Formula 2001! Just let it sit for a few hours. I wish I had a digital camera... it looks great!
Old Oct 18, 2003 | 08:23 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
no washing off? im scared of spraying stuff in my engine bay
Old Oct 18, 2003 | 08:38 PM
85_ZED28's Avatar
Car: '85 Z28
i did this with "GUNK" when i first got my car. Sprayed everthing, let is sit for a bit, then hosed it all off. Worked great.
Old Oct 18, 2003 | 11:22 PM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
fellas.. simple green ... just sprey it every where (not when hot) it works miricles.. i use it all the time..
Old Oct 19, 2003 | 12:26 AM
MasterEvilAce's Avatar
I used something in a purple bottle (Lightning something?)
it's a de-greaser it says
I hooked up the bottle to our pressure washer, sprayed down the engine bay
started the car, and let it heat up, and sprayed it some more
then i sprayed off everything with normal water.. worked wonderfully. (Not 100% better.. but noticably cleaner)
didn't have to worry about the airfilter since i have a TPI engine :lala:
Old Oct 19, 2003 | 12:29 AM
CaysE's Avatar
no need to wash it off. It's not like you'll be hurting anything. Just don't spray into the air intake and you're fine. Seriously, spray it on everything and let it sit, and you're done. It works a little better if you powerwash first and let the water dry.
Old Oct 19, 2003 | 12:37 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Everytime I clean my engine something major breaks within a day or two. Last time it was the timing chain on my 454. Turned my push rods into spaghetti. I'll just leave mine a little "dusty" until I pull it for the rebuild.
Old Oct 19, 2003 | 12:38 AM
CaysE's Avatar
LOL... if water or formula 2001 broke your timing chain, i'd say it was about ready to go anyway..
Old Oct 19, 2003 | 01:55 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Yeah, just a crappy GM design team fubar.
A junk metal gear with neoprene teeth. I should have known to replace the damn thing as soon as I bought the truck. I immediately changed my T/A to a double roller.
Old Oct 22, 2003 | 05:21 PM
CaysE's Avatar
Anyone tried it yet? Let's see some results.
Drone358
Dec 10, 2015 08:16 PM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
ericjon262
Sep 11, 2015 06:07 PM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
