Burn...baby...burn...(video)
Car: 88 IROC
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Well, there are better ways, such as a line lock.
But I bet he just pushed the brake, and then mashed the gas till the engine overcame the brakes on the rear wheels.
Car: 88 IROC
Originally posted by 19doug90
how do you lock up the front wheels like that?
But yeah, its jiust a simple brakestand, the key is putting enough pressure on the brakes to get the fronts to lock but the rears to be able to overcome like FruityOne said.
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Yeah I think it went into 3rd gear, then downshifted back into 2nd when he took off...
Pretty badass
Pretty badass
Car: 88 IROC
Pretty badass
Pretty badass
It was kinda the last one with the peanut cam cause i have a 95 LT1 cam sitting in my room.
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
Originally posted by SpeedJunkie
Yeah when it shifted into 3rd i was like ****! cause i wanted it to burn more in 2nd and it did downshift when i took off again.
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
i'm definitly assuming its an auto... but how did u get it to shift through the gears like that? most of the ones i've seen, the guys just rev the :
ig latin::"it-shay" out of their cars in like first or something. did u throw the shifter into first and manually tap it forwards? very curious. thanks
ig latin::"it-shay" out of their cars in like first or something. did u throw the shifter into first and manually tap it forwards? very curious. thanks Supreme Member
ig latin::"it-shay" out of their cars in like first or something. did u throw the shifter into first and manually tap it forwards? very curious. thanks Or you could manually shift it.
Car: 85 IROC
Engine: L-69 305
Transmission: T-5 manual
peanut cams do great burnouts
untill teh tires get sticky enough to bog down the poor 305
it was the greatest thing ever though, massive smoke
il tell you how i like the vid when its done downloding in an hour
damn 56k
wahoo, its finally done, not bad man, i love doing a roll out like that
damn 56kwahoo, its finally done, not bad man, i love doing a roll out like that
