Will these rims work on my car.
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
will these work on my car without adapters or spacers or any kind of modifications.
Vendor: Eagle Alloys
Product Line: Eagle Alloys 077 Series Wheels
Material: Aluminum
Finish: Polished
Width: 8 in.
Diameter: 17 in.
17 in. x 8 in., 5 x 4 3/4 in. bolt circle, 5 15/16 in. backspacing, polished finish, 077 series wheel
Material: Aluminum
Finish: Polished
Width: 8 in.
Diameter: 17 in.
Car: 89 camaro RS
are there any 17" wheels that don't require spacers for cryin out loud and by that I don't mean complete custom wheels. I have about $700 to spend on wheels not wheels and adapters.
I really like those but if I have to use an adapter I guess I will find something else.
I have a set of those in my garage... gonna fix them up during the upcoming break.
Anyway, you need to measure from the back. Put a straight edge (anything straight) across the length of the wheel and measure the space between the bolting surface to the striaght edge you are using. Probably 4.5".
That being said, I would use 4.5" backspacing in the rear, and around 3.5 - 4" of backspacing on the front with either a 7 or 8" wide rim. Some people say 4.5 up front is fine, but mine ALWAYS RUB!!!
Car: 1990 Camaro RS
Engine: LO3: 305 TBI
Axle/Gears: 1997 Trans Am rear w/ posi -3.23
Yep
Car: Camaro
These are Pacers but they were made by Centerline for Pacer as shown by the manufacturers stickers on the box when I got them. They were $650 for all four 17 x 9.5 w/ a 5.5" backspacing.
I really need to polish them again.
