People WITHOUT wheel adapters.
Old Nov 20, 2003 | 05:44 PM
supermaxxbasher's Avatar
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
Are there any 17" wheels that don't require wheel adapters. I don't mean expensive custom wheels like boyds. I have about $650-700 to spend on wheels and I don't want to have to by those wheel adapters. SO if anyone can help will be appreciated and if you have pictures of your adapterless wheels please post.
Old Nov 20, 2003 | 08:14 PM
Bandit5's Avatar
You don't need spacers if you keep the same width and backspacing.
If you have 16 x 8 wheels, get 17 x 8 with the same backspacing, and find tires with the same overall diameter and it will bolt up just fine with no problems.
Old Nov 20, 2003 | 09:55 PM
Car: 89 camaro RS
there inlays the problem. I have 15x7 wheels
Old Nov 21, 2003 | 06:57 AM
CrazyHawaiian's Avatar
Car: too many ...
But if you get a 17x8 with the same backspacing as the 16x8, which also fits your car by the way, then the 17x8 will bolt up as well. The problem is finding some 17x8's with the same backspacing as the stock 16x8 Camaro wheels and staying within your budget. I dont know if $700 is enough to get a set of 17" rims and 17" tires. You might have to settle for 16's for that price.
Old Nov 21, 2003 | 07:31 AM
Nazzz28's Avatar
Car: 91 z28
Transmission: 700 R4
I agree with CrazyHawaiian that it will be hard to find 17x8 wheels
with 4.5" BS in your budget. I personally would save the extra
$400 and get some nice two piece wheels for $1000-1100. This
way you can have a wider selection in styles and in sizes. I have
17x8 front and 17x9.5 rear centerlines and got them with 4.5"
and 5.5" backspacing respectively for ~$1100 shipped to my door
through Summit. By saving up the extra money I now have a
wheel that I like, with the back spacing that doesn't require
adapters.
This site is really good for the Boyd wheels and offers 17" sets for
$995.
http://shop.sportruck.com/bcodd/
This is just my suggestion, but good luck with your search.
Old Nov 21, 2003 | 07:34 AM
Nazzz28's Avatar
Car: 91 z28
Oh by the way here is a pic of my rear wheel, love the deeper dish. I really need to get some better pics. If you want the pics bigger I can do that.
Old Nov 21, 2003 | 07:35 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
actually.... no.
you dont need spacers if you get wheels with the proper backspacing... width has nothing to do with it.... it just cant be too wide to fit in the wheel well.
so if you found a 14x4" you wanted or a set of 18x9.5" you wanted, as long as the backspacing allows it to fit, it clears the brakes, and it has the proper bolt pattern, you can bolt it on.
(theres also the issue of it being able to take the weight of the car, but every modern wheel ive seen can more then handle 3rdgens...)
now to the problem....... 3rdgens have wierd backspacing. so you are limited in the number of bolt on wheels. 2wd S10s have the same backspacing, so if you want to use them you can....
now to the reasons alot of people have 4thgen and C5 wheels...... they're cheap... the 10spoke camaro rims are well under 1k for wheel and tire.... add on $300 for the adapters and they are still a great deal.
i know you said you dont want to run adapters because of the cost issue, but wheels/tires are expensive....
if you poke around enough however, you can find later 16" stock 3rdgen wheels cheap.
matter of fact, i have some cruddy 15" early Z28 rims in the garage that i cant even get rid of.. lol.
Old Nov 21, 2003 | 07:37 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
$995.
SHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH!
thats what im getting... i dont want thoes to be the next TT2s... everyone has TT2s.........
Old Nov 21, 2003 | 07:42 AM
Nazzz28's Avatar
Car: 91 z28
Sorry my lips are sealed . I wish I saw this site earlier, but I like my centerlines and they are really unique. The only thing I regret is that I should have went with 18", but with the roads in Vermont maybe I am better off.
Old Nov 21, 2003 | 08:06 AM
Car: 89 camaro RS
thanks guys.
Old Nov 21, 2003 | 08:15 AM
Car: 89 camaro RS
THat price I listed didn't include tires at all. But after seeing these rims I am in love and I guess I can throw another $250 at a set of 17" rims. Here they are http://shop.sportruck.com/bcodd/cast/smoothie.htm
what offset do I need to get if I went 17x8 all around.
Old Nov 21, 2003 | 08:52 AM
Car: 89 camaro RS
here is another set I have considered http://www.centerlinewheels.com/whee..._17%20x%208ed. I like this set the best though and they are the exact same price too.
Old Nov 21, 2003 | 10:12 AM
Nazzz28's Avatar
Car: 91 z28
If you want to use 17x8 all around go with a 4.5" backspacing.
I have the Centerline Matrix 5-spokes and went with a 17x8
with 4.5" BS up front and 17x9.5 with 5.5" BS so I could have a
wider tire in the back. For tires I used a 255/45-17 up front
and a 285/40-17 in the back and it looks really good. I would
personally go with a wider wheel than 8" in the rear if you are
going to spend the money.
I have seen a thirdgen with the dagger wheels on the centerline site and have posted the pic on here somewhere, you'll have to search.
Here are some pictures of my wheels
Old Nov 21, 2003 | 10:13 AM
Nazzz28's Avatar
Car: 91 z28
Here is another they are 17x9.5 rear wheels
Old Nov 21, 2003 | 10:14 AM
Nazzz28's Avatar
Car: 91 z28
Here is a picture on the car kind of showing the width the the rears.
Old Nov 21, 2003 | 11:17 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I went with the ROH snypers. They are 17x9 all around but I can't remeber the backspacing. I ordered the ones made for 3rd gens. You can get them as low as 209 a wheel which is a great price for a wheel of this size. You will spend far more on good tires than you will wheels. Unless you get HRE's, Iforged and a couple other super nice wheels. I spent about 800 for tires and 800 on rims.
Old Nov 21, 2003 | 12:11 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
i just bought 17x8 snypers for 160 a wheel, theres deals out there.
Old Jan 22, 2004 | 01:03 PM
Car: 89 camaro RS
I just was looking at some boyds and I noticed that the smoothie 2's have a 17x10" width avaliable and I was wondering would those fit in the wheel well or not and what BSing would I need for a rim that big..
Old Jan 22, 2004 | 06:15 PM
Kandied91z's Avatar
any 2 or 3 piece billet wheel is cutom made to fit your wishes. however only a few companies offer the barrels in 1/2 sizes so often your stuck with 7,8,9,10,11,12,etc sizes.
my 18x10's fit in the rear with no problems however i recently had the backspacing adjusted to line up with the fronts which require some modification of the inner fender to fit.
6-700 is reasonable on the cheaper 17" wheel but don't expect to get tires for that price. dealer cost for wheels like boyd and the rest are easily close to 300 a wheel. the smart decision would be to save up a little longer and get what you really want.
Old Jan 22, 2004 | 07:37 PM
85TransAm406's Avatar
Car: 1985 Trans Am
Kandied-
What is your current backspacing on your 18x10s? I have already made some extra room in my rear wheelwells, i want my wheels in as far as possible without modifying the rear suspension (bumpstops are gone, though).
Old Jan 23, 2004 | 07:26 AM
LUVmy92's Avatar
Car: Camaro
Here is my wheels, $650 for the set 17x9.5. Tires were close to a grand extra!
Old Jan 23, 2004 | 09:23 AM
Bandit5's Avatar
Nazzz28, can you post a better picture of what the wheels look like ont he car? I have been lookign at the Matrix wheels for almost a year now. Also, how much did they cost?
Old Jan 23, 2004 | 10:52 AM
Car: 89 camaro RS
LUVmy92, Where did you get those rims at cause i am really digging them..
Old Jan 23, 2004 | 11:18 AM
Nazzz28's Avatar
Car: 91 z28
If you go to my cardomain site you can see some more pics of my
car. I bought mine through Summit and they were ~1100 for all
four, free shipping. I really like the design and think it looks good
on thirdgens. If the pictures aren't big enough I can probably
e-mail you a larger image because I think I had to resize them for
cardomain.
Old Jan 23, 2004 | 12:20 PM
LUVmy92's Avatar
Car: Camaro
A buddy of mine runs a custom wheel shop, he got them for me. Thy are made by Centerline FOR Pacer. Kind of odd that they make wheels for pacer???It had the shipping Label from Centerline to Pacer both with seperate part numbers but they are only offered by Pacer. Dont know if they still make em or not.
Old Jan 23, 2004 | 02:07 PM
Kandied91z's Avatar
the new is 6.75 rear and 4.75 front for my 8/10 18" setup. requires slight modification of the inner well. basically the ridges that you see on the inside need to be flush...either bang them out or what i did was have a new plate welded. it's only 1/2" max keeeping them from working right, once it's modified they work perfect and the tires fit the stock dimensions so if you want to lower the car you'll have no problems.
Old Jan 23, 2004 | 06:17 PM
Car: 1985 Trans Am
What was your backspacing prior to the adjustment in the rear? Also, any pics of the wheels on the car with the new b/s?
Old Jan 24, 2004 | 02:07 AM
Kandied91z's Avatar
i don't have the rims yet....
i moved them 2" in so the backspacing would go accordingly..
Vintageracer
Jan 10, 2020 05:33 PM
Scamo-2.8
May 20, 2016 07:01 PM
deracer
Apr 11, 2016 12:04 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
