Best way to paint an engine?
Old Jan 27, 2004 | 10:45 AM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
Im looking at getting a crate engine from cm parts direct... im almost positive they dont paint em though. I am looking to paint the block red. Whats the best way to do this? What paint? And finally what all will i have to remve from the engine or can i leave most of the parts on while i do it? thnaks everybody
Old Jan 27, 2004 | 11:12 AM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
I just got my 383 stroker rebuilt at the local speedshop and they didn't paint it, but they hot tanked everything and primed it. Then when I picked it up, I just went and got the spray cans of engine enamel (tested up to 1200 degrees) and did 3 coats of chevy orange and 2 coats of clear and looks hot! As far as taking the engine out, mine was already out, but I'm sure it would be hard and the paint job wouldn't be as good doing it with the engine in.
Old Jan 27, 2004 | 11:24 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
it will be painted black.
i reccomend VHT engine enamel if you plan to paint it a diff color.
Old Jan 27, 2004 | 11:30 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Its not too bad doing and enigne in the car... i did it.
The valvecovers I took off to paint (stock stamped) and wrapped the pulleys with newspaper so I could do the waterpump, balancer and front of the block/heads.
The only hard part really is under and around the exaust manifolds.
(I used a spray can for this too)
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
