Any lowered cars come inside(especially Camaros)
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i never thought about drop spindles. anyone got them with the stock springs? (looking for a somewhat soft spring for drag racing use without going to a full drag race spring, i want to keep it somewhat streetable.)
wonder what the car would look like with 275/50/15 out back with stock ride height (or alittle lower maybe) with a 205/65/15 up front with a drop spindle (1" or 2"). remember this is a sport coupe i am talking about.
Car: 84Z28
Engine: 12:1 355
Transmission: fairbanks turbo350
thats what i was running v6springs and dropspindles and stock struts now im going to stock spindles and 90/10 drag struts and the same springs.
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
my iroc is lowered like 4.5 inches and i scrape like everywhere i go..its nuts...
but you learn to know where you are driving!!!
trust me...after goin back to the body shop a few times, your wallet starts to hurt...
i took the "air dam" off long time ago...maybe thats why my car heats up? meh..oh well..too late to put it back on iguess...
iroc2nv
iroc2nv
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
Originally posted by c-u-later
my headers allways hit the ground with my 2"drop spindles on. heres a pic with them on. i put the stock ones back on this year.
Car: 94 Corvette
Engine: LT-1
Car: 84Z28
Engine: 12:1 355
I think maybe the v6 springs are the reason my headers hit so bat with the drop spindles. im sure if i was using v8 springs it might not drag my headers so much,oh well. GTA-SPD im not selling my drop spindles,im thinking about buying a IROC z and putting them on it.
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Even going up small hills expect it to scape.
You just have to deal with, it or live somwhere else.
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Originally posted by CustomX
I dont go anywhere with speed bumps, driveways etc, basically you need to learn to drive where you wont get hurt bud.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by 9T1 Z-28
Here's mine with Sportlines. I scrape my airdam on everything. However, I am VERY careful about trying not to scrape the front spoiler.
Car: '90 RS
Engine: 377 LSX
Originally posted by 1992rs/ss
I used eibach's to drop mine
Engine: 7.0L
looks to be an ss hood, however, i think that the cowl would look equally good if not better.
Car: '90 RS
Engine: 377 LSX
Oooh you may be right. From this angle it looks like just a simple low rise cowl hood. I like the looks of it from this angle whatever it is.
im looking at everyone cars with sportlines and the rear seems to be high on their cars too, what the hell, i guess im gonna have to spend about 200 to get some ground control ride height adjusters.
Car: '90 RS
Engine: 377 LSX
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
Thats another great looking car. Seems like lots of super nice cars are emerging on t
it is an SS hood
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
IIRC, the rubber dampers are supposed to be removed from the rear when using aftermarket spring kits, thats easily another inch drop...which might be the reason some people have a higher rear than others with the same springs.
Car: '90 RS
Engine: 377 LSX
i took mine out , but in the pic i shouwed they were still in, i took them out and used a piece of heater core hose and then taped them on also , it lowered it about an 1/8 inch , i cant wait to see if the car drops any more , i only had them on for about 200 or less miles last year , i hope it goes down a little more .
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
Car: 1991 Camaro Z28
Engine: 5.7L TPI
My car sits 0.5 to 1.0 inches higher on the driver's side! That may not sound like much to some, but it is a HUGE dofference to me. It drives me nuts. I am not sure if I did something wrong when I installed the springs or what? I think I am going to try to swap the swpring around to see if that levels things out a bit.
I think that I will also remove the spring insulators. Has anyone noticed any extra noise when removing the insulators? I figured there may be some nose after doing that since there will be a metal spring in a metal housing.
Car: 92 Z28
Engine: Boosted LSX
Needs to be a tad lower. still a little to much gap between the Fender and tire
OLD PIC..
Now This is low.... Just a messin around Photo. I had to pull the springs for a bit. To move my convertable around.
This is no motor no springs
Its a work in progress. just need to find time to finish D/Aing it to paint it. and put my 92 front clip gfx back on.
OLD PIC..
Car: 86 camaro
Engine: 2.8 multiport cross fire injection
Transmission: 5 speed
damn tpi383 that looks awesome!!!!!
bet the exhaust would drag the ground all the time tho lol.
all these lowered cars lok awesome i think im goin to do my sport coupe now!!!
you guys that lowered em and are settin kinda level in front and back did u lower it on all four corners?
because i want mine level or maybe a lil tiny bit more in front then rear.
would cuttin coils work all way round i assume it would.
i have to figure out whether its my shocks and or coils that need changed in mine tho 1st.
one other ? u use stock shocks or have to buy lowered shocks for em w/ a half coil cut or a 1 to 1 and half inch drop springs on all 4 corners?
Engine: 7.0L
i wouldn't suggest cutting the coils if one could avoid it, it really messes with the spring rate.
Car: 94 Corvette
Engine: LT-1
I cut the rears in my GTA, and it rides fine. I cut the fronts in my old 82, and it rode fine too. I still wouldn't suggest it though.
All it takes is a 1/4 coil too much and bam, your sitting on the bump stops. Don't ask how I know this...
The best way to go is with spindles, but since those are as hard to find as an honest politician, I'd go with springs. For like $200 you can get a good set of four. I only cut my rears to figure out where I wanted it, now I'm going to buy some springs and do it right. As for the shock question, stock shocks & struts will work just fine. I don't even think they make "lowered" struts for our cars.
The best way to go is with spindles, but since those are as hard to find as an honest politician, I'd go with springs. For like $200 you can get a good set of four. I only cut my rears to figure out where I wanted it, now I'm going to buy some springs and do it right. As for the shock question, stock shocks & struts will work just fine. I don't even think they make "lowered" struts for our cars. Supreme Member
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
yep im with you.......
I cut a 1/2 of a coil off my dropzone lowering frt springs and its very close to sitting on the bump stops..but then again my suspension travel is very minamal too but still 1/4 of a coil too much would make a good spring be an expencive peice of junk metal rod ahahah.
Theres a guy here with a blue iroc forget his id name but his name is Joe....and he once ran cut stockers on his iroc and it rode harsh he said and now that he runs proper lowering springs he thinks cutting stockers really sucks.
And yes mw66nova is right cutting a spring makes the spring rate stiffer.
Car: 85 Camaro Z-28
i installed the hotchkis springs on mine, and i also put new struts on the front when i changed the springs, its about an inch lower, should sit a little lower once everything settles. mine drags when i pull in my driveway, but my driveways steep. i have to be careful not to drag the front spoiler, so i cant really go any lower. i think it looks ok now, i just wanted some of that gap gone between the fenders and tire.
Car: 1989 IROC-Z
Transmission: 4 speed auto
baged
hey, i dont have my roc yet (going next weekend), but i was wondering if anyone threw up the idea of an airbag suspension. this way if you know ur going up a driveway or something low you can raise the car up a few inches, so u don't hit. i don't know much about airbags thou, i dont know what you would have to do to get them to fit a 3rd gen. what do you guys think, would that be good or *****?
albert III
albert III
Airbags will give the smoothest ride, but once you lower these cars, you really only have a little bit to play with. You will need to get the price for the bags, tank, motor, and switches. This will be a big factor to see if it is even worth the money to put them in. Springs on average are around $160, the average bagging will cost about $1200-$1300.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
