eibach prokit all around now.
Old Mar 4, 2004 | 12:35 PM
MdFormula350's Avatar
before (front pro rear drag springs)
after
Old Mar 4, 2004 | 12:37 PM
rear before
after
Old Mar 4, 2004 | 12:38 PM
front
Old Mar 4, 2004 | 12:42 PM
hard to tell since its dark outside but i think it looks alittle better. right now i think i am happy.
i drove up on the curb alittle bit and i am still using the rear airbag on the passengers side.
Old Mar 4, 2004 | 01:03 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
looking good,
where can i get sportlines for a good price?
Old Mar 4, 2004 | 01:38 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
That looks good, I wanna lower my car this summer, but not too low. How much was the total drop do you think?
Old Mar 4, 2004 | 01:52 PM
nolanr0413's Avatar
Car: Trans am
well i cant tell the difference, how does it ride , do you like the ride better now of with the drag springs.
Old Mar 4, 2004 | 02:12 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
oddly it appear to sit almost the same, i say take out the rear isolators to get that back end to sit further down, then ull be good to go.
Old Mar 4, 2004 | 02:38 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
I can see a little bit of a drop, I like it just like it is. I dont think you need to drop it anymore.
Old Mar 4, 2004 | 03:00 PM
87rediroc's Avatar
Car: 87 Iroc (summer only)
Engine: 5.0 TPI
Transmission: 5 speed
My car sits similar, with the same kit. What effect would removing the rear isolators have besides lowering the rear? I want the car to have a more level stance. MdFormula350, your car always looks good. Love the ronals.
Old Mar 4, 2004 | 03:03 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the look is so similar that i probly would have kept the drag springs in...
unless you're changing what you're doing with the car......?
Old Mar 4, 2004 | 03:31 PM
i have the drag springs still, was going to sell them.
just trying different things.
might try v6 springs next. or sportlines.
yeah its not bright out and i think they need to settle some alittle.
Old Mar 4, 2004 | 04:47 PM
Stevo's Avatar
Car: Pair of 92 Z28s
ya its hard to tell but i think i can see a little difference..
Old Mar 4, 2004 | 04:54 PM
llvll4l2c91350's Avatar
about another 1/2 inch lower at the back would look perfect
Old Mar 4, 2004 | 05:22 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
It sits about how mine does after I changed the stockers out for the Prokit. I didn't really see that much difference in the change in the back of my car, but the front is where I saw the most noticable difference in my car. Same seems to be for yours...
I think it looks good!!!
Old Mar 4, 2004 | 05:56 PM
yeah very little difference since i still have the airbag in the back at 12 psi
but its alittle lower
i also have to say i have very little psi in the rear tires
Old Mar 4, 2004 | 09:51 PM
Orinackra's Avatar
Hows that gonna work? For the front I can see, but arent the springs the same in the rear?
Old Mar 5, 2004 | 12:55 AM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
V6 Springs in the front are killer for weight transfer for good launches out of the hole. I've used Moroso trick front springs and stock style 6-banger springs in my Nova, and the 250-6 springs I must say worked a teeny bit better, but the Moroso springs were more streetable. They both had the same exact stance.
Old Mar 5, 2004 | 02:52 AM
theSteve's Avatar
Car: 1985 Trans Am
Engine: upgrading...
Transmission: upgrading...
sure you have sexy new springs.. but at what cost? your lawn looks horid now!
lol
Old Mar 5, 2004 | 07:30 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i can't really tell the difference between the before and after. maybe it'll settle a lil bit too after you get some more miles on it. Sweet formula btw....:hail:
Brandon
gixxer92
May 18, 2017 11:20 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
