Who's Project Car is Not Moving Yet?
Car: 1986 Firebird
Engine: 305 V8 Currently being rebuilt
Transmission: 5 spd
I know its not a current pic but my engine is pulled and being rebuilt. I'll post pics later, but its been off the road since September......
Car: 87 Camaro SC
Transmission: 5-Speed
My project has been off the road since Feb 03 after failing emissions testing. Decided to swap in a TPI 305, after finding a good deal on one. Complications lead to it being off the road wayy longer than intended. Add to that my returning to school last year. Needless to say, I have almost everything I need to put her back on the road, just have to get my *** in gear. HAS to be done before Feb... 2 years is far too long to be without My Camaro
Car: 1988 formula
Engine: 5.7 l98
Transmission: a4
bought the car january this year needed a new starter and tune up. then i got into it. new interior all new body panels new suspension engine rebuild all is coming together this winter, paint will be done soon to 6 coats of a base red with metallic and pearl flake 9 coats of clear then msking the flames and doing another 3 coats of clear for a ghostly flame:hail:
out of pocket cost for me $300 for the car
having a dick head father paying child support after 14 years payed for the rest
Car: 1991 Formula
Transmission: 5 speed
Sorry no pic's. The '91 is driveable but sitting in the parking lot of my printshop under 2 covers. The front end is off(all but the hood)and the corner of the core support straighted. After I finish cancer treatment in January and get my taxes back,she's going in the shop to have the frame straighted, 2 new fenders, a new hood, and the engine compartment repainted. Then she comes home and the rebuild begins. Chris
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
my project isn't moving but it will be done in the spring. i just finished all the paint work and putting it back together. so looks like im just waitin on an engine. im gettin a scott shaffirof 434sbc. once i get a little bit more money i can order it. then i got to save up for a 9" rear and better trans.
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
finally got mine on the road for a whole 2 days, haha no i put her back in today cause one of the injectors is bad brand new too, and putting on some front end parts and removed the ac, hopefully it wont be another 6 months, although i did get it completly dissasembled hopefully ill be able to finish puttin on the body parts within a week
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
1 week porkyzilla time = 2 months real time
mine will be down no more than a year because I need to smog it december 2005 my motor has a slight knock so Im building a new one that will run at least 12.3 N/A and be CA. smog legal and will run good on our cat **** 91 octane
Engine: 5.7tpi 350,
cant be 2 months i move at the end of the month
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Well, my GTA has been down since september '04 now.... I sold the 355TPI/T56 out of it and I have my H/C LS1 sitting on the engine stand ready to go in.... me and my fiance are getting ready to buy a house, but I'm still hoping to have it on the streets in the summer of '04... not much left to buy to finish putting it back together... here is what I have ready to go in it and what is already in it....
*346ci LS1
-ported LS1 heads
-comp 918 springs
-titaniuim retainers
-hardened pushrods
-thunder racing cam
-ASP pulley
-ARP rod bolts
-ported LS6 oil pump
-double roller timing set
-custom made LT headers
-dual electric cutouts
-stock 4th gen WS6 catback
*T56 tranny w/ a B&M ripper and a Lou's short stick on it
-LS1 aluminum driveshaft w/ 1350 rear yoke
-spohn T56 x-member
-fbody motorsports LS1/3rd gen motor mounts
-stock k-member (powdercoated) notched for AC compressor
-powdercoated a-arms and spindles modified for front LS1 brakes and all new poly frontend rebuild kit
*Moser 9" w/ 31 spline axles, aluminum center section, 4.11's....
-polished jamex STB
-SSM SFC's, Lakewood LCA's and APHR
-KYB shocks/struts
-AR 220 rims... 17x9.5" and 17x11" with 315/35's on the rear
-Hurst Line Lock
**That is about all that is sitting around in the garage or else already in the car... after this I'm still planning on repainting it green with a RAI hood and putting black interior in it with white faced gauges and an a-pillar pod with gauges and a hidden shift light. Here are a few pics....
Car as it sits currently....
Moser 4th gen 9"
Later- Jeremy
*346ci LS1
-ported LS1 heads
-comp 918 springs
-hardened pushrods
-thunder racing cam
-ASP pulley
-ARP rod bolts
-spohn T56 x-member
-polished jamex STB
-KYB shocks/struts
-Hurst Line Lock
Moser 4th gen 9"
Later- Jeremy
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
Ive got a long long long way to go deadline is may 1st i hope i can have it done im workin buildin a new motor gettin tthe trans built swappin rearends, new paint, new interior but mainly none of this can be done untill im done welding in rust holes! ill have pics up in the next couple days kee an eye out for project RS RESCUE 911
AkDrifted
Aug 17, 2015 07:45 PM
db057
Aug 11, 2015 10:11 PM
novaderrik
Aug 10, 2015 12:44 PM
