Just ordered my new wheels.......
Old Mar 20, 2004 | 02:12 PM
FLYNLOW92rs's Avatar
Well I ended up going with the following style.....
As far as the specs go? Well here they are, I know they are big, but for show, I like them.......
FRONT
19x8 w/ 245/40/19 tires
REAR
19x9.5 w/ 265/40/19 tires
Feel free to share opinions, comments, suggestions, etc.......
Old Mar 20, 2004 | 02:15 PM
THE BANDIT-Z's Avatar
Car: 1985 Black IROC-Z
Engine: 305 T.P.I (for now)
Transmission: TH700"R"4 (R for Racing)
Cool , a little big one wheel size for a camaro but I think thell look ok with the correct tire size? Cheers.
Old Mar 20, 2004 | 02:21 PM
Chet's Avatar
Car: GTA
Not bad, I love wheels with a lip. About 150x improvement of your old ones. But I think a 275/40 in the back will be better fitting. 265 seems a little narrow for a 9.5 width wheel.
Old Mar 20, 2004 | 02:55 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
haha kandied is going to be so jealous of your 19" ......... wheels ..... nice choice though very nice style cant wait to see em mounted up
Old Mar 20, 2004 | 03:10 PM
grngryoutmyway's Avatar
Car: 92 Z28
:rockon: :hail: VERY nice I like those alot, a million times better than current... maybee more. Would look cool if you incorporated a tiny amount of body color, like maybee painting the bolts on the lips teal.
Old Mar 20, 2004 | 06:41 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
A little too bling bling for my tastes, but they are a whole truckload better than what you had!
Old Mar 20, 2004 | 06:43 PM
Kandied91z's Avatar
very nice, i like that overall design of wheel as well. however i don't particularly like the tire size choice as the front will be taller then stock which might give you issues on lowering as well as make the car have that larger rim/larger height issue.
i see why you might have done it as this route give you a taller sidewall for rim protection. just hope it turns out the way you like. i'd be nervous with those 19's though......hope you have good roads.
Old Mar 21, 2004 | 12:36 AM
25THRSS's Avatar
shoulda gone with a wider rear tire
Old Mar 21, 2004 | 09:17 AM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
i wouldnt chance any wider on the rear with 19's
Old Mar 21, 2004 | 09:55 AM
Stevo's Avatar
Car: Pair of 92 Z28s
i cant see the pics i get a red x...
Old Mar 21, 2004 | 10:08 AM
xpence's Avatar
I don,t see the pics either
Old Mar 21, 2004 | 10:09 AM
xpence's Avatar
oh there it is, those are sweet
Old Mar 21, 2004 | 01:05 PM
Kandied91z's Avatar
9.5 or 10 is plenty wide enough and way more then enough for his intended purpose. i'm assuming that they don't offer a 10 correct?
either way it should look good. you'll be really happing going 8's in the front, especially with your style. what offset or backspacing do you have on them?
Old Mar 21, 2004 | 07:41 PM
25THRSS's Avatar
I said TIRES, as in rubber. 265 on a 9.5 inch wheel aint ****e.
Old Mar 21, 2004 | 07:49 PM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
pretty sweet looking rims!
Old Mar 23, 2004 | 03:07 AM
Kandied91z's Avatar
well 265 is the right TIRE for the application so unless he wanted to look like he was straight out of a vintage hot rod magazine he should go to a larger rim to run a wider tire or do what he is intending. 275 would be ideal but then there would be another set of problems as well as the overall tire height would be even more off.
looks like hell running the wrong tires on the wrong rim widths...sometimes you have to make due.
Old Mar 23, 2004 | 07:07 AM
CrazyHawaiian's Avatar
Car: too many ...
Cool! I recommend 245/35/19 front and 275/30/19 rear, both with re-inforced sidewalls. Be sure to keep the load rating in mind when ordering. Taller sidewall will provide better comfort, but also throws the speedo off and raises the chances of rubbing issues when the car is lowered. When comparing 245 to 275, the front sidewall should always be 5 higher to make them look even. With the same size sidewalls, the fronts will look fatter than the rears. Nice wheels!
Old Mar 23, 2004 | 07:39 AM
sbrice18fan's Avatar
Car: 1990 Chevrolet Camaro RS
Those wheels are going to look good on your car, although I have never seen 19's on a 3rd gen.
Old Mar 23, 2004 | 01:39 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Ballin'
Old Mar 23, 2004 | 05:05 PM
camaro05's Avatar
Car: 91 Z28
banging!
Old Mar 24, 2004 | 07:46 PM
GOFASTER's Avatar
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
flyinlow
where did you order them from. how much for em? I have ran them rims on my truck, good priced.
Can you hook me up with the site??
Old Mar 24, 2004 | 08:15 PM
Originally posted by GOFASTER
flyinlow
I bought them from a local shop here in town......
The wheels are being shipped directly to ThirdgenResource via FedEx, so they'll be waiting for me on Saturday/Sunday
I'll post pictures that night
Old Mar 24, 2004 | 08:17 PM
BadBowtie88's Avatar
Can't wait to see those pics!
Old Mar 24, 2004 | 09:22 PM
BlueByU's Avatar
Car: 1991 Z28
nice rims, i like the 5 spoke style. 19's are too big though, imo.
Old Mar 28, 2004 | 06:37 PM
1badblue87z's Avatar
can't wait to see the pics :hail:
Old Mar 28, 2004 | 06:56 PM
johnyIROC's Avatar
should have went 35 or 30 series on the front for sure... but other than that, sounds good... your old wheels were horrible.
Fireslash
Apr 11, 2016 06:43 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
jaridjohn
Oct 5, 2015 07:01 AM
Bigold4x4
Sep 28, 2015 05:21 PM
