Q for those w/ lowered cars.
Old Mar 21, 2004 | 12:28 AM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
How do you get under your cars? I can barely do it now and it's stock height. Even using a lift the arm catches on my cat.
Old Mar 21, 2004 | 12:33 AM
83crossfire's Avatar
Car: 83 firebird, 95 tahoe
Engine: crossfire 305
I have the intrax lowering springs. It is a two man job to get it on a lift. One person had to pull up on the fender, while the other sets the lift. At home my jack is low enough to fit under.
Old Mar 21, 2004 | 06:26 AM
nolanr0413's Avatar
Car: Trans am
i have to use a custom block . Its a 2x12 by about 20 and then the next layer is a 2x12 by 12 , so the car can step up on . And then i finally can get under it. ANd the rear i just need to use a 2x4 to get under there.
Old Mar 21, 2004 | 06:52 AM
Steve86TA's Avatar
Car: To many to list
Same here
Old Mar 21, 2004 | 07:12 AM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
Why use blocks of wood when you can get a jack that is designed for lowered cars?? That's what I use, then I put a jackstand underneath. Seems simple enough!
Old Mar 21, 2004 | 08:20 AM
CrazyHawaiian's Avatar
Car: too many ...
Same here I use pieces of wood. Back up onto the wood, then use the special jack for lowered cars and it just fits hehe.
Old Mar 21, 2004 | 11:02 AM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
i have to jack up the front of the car under the front bumper on the (black plactic) jack points then slip a jack or the hiost arm under the the subframe.
Old Mar 21, 2004 | 01:07 PM
Steve86TA's Avatar
Because the wood was a little cheaper than a jack. And I dont have to jack up my car enough to warrant buying a special jack
Old Mar 21, 2004 | 02:53 PM
MdFormula350's Avatar
i use a big sears floor jack, but before i can get that under the k-member or rear end i use the prolift jack i got from advance auto parts to get the car up enough for the big jack to slid under.
Old Mar 21, 2004 | 08:07 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Where do you get such a jack?? I would love to have one and have looked for one over the last 3 years. I always have to use the stock one to raise the front enough to get the other one under the k-member. It is such a pain.
Old Mar 21, 2004 | 11:21 PM
Car: too many ...
They are usually called Aluminum Racing Jacks. I've seen them at Sears for around $170. You can usually spot the low profile design by looking at the rollers in the front. Traditional jacks will have two wheels under the jack, these new ones have a single 'steam roller' style roller that makes the front sit lower. Here's an example of the Sears one:
But IMO these ones from Sears are still kind of high. I forget the brand, but there are some out there that are EXTREMELY low profile (and run like $500).
Old Mar 21, 2004 | 11:52 PM
BMoneySS's Avatar
Car: 2002 Camaro SS
Transmission: T-56 6 Speed
I have seen that jack at sears and it is awesome. it is still kinda high. I geuss I am looking for a jack that is only like 4" tall or so.
Old Mar 22, 2004 | 12:28 AM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
Harbor Freight has a better one for about 125 when its on sale. its around 4 inches.
Old Mar 22, 2004 | 01:23 PM
speed88's Avatar
Engine: 383
I bought mine at Canadian Tire, seeing as how I live in Canada and all. LOL But seeing as how I can get then there I would imagine you could get them at Sears or Autozone and so on.
Old Mar 22, 2004 | 01:24 PM
speed88's Avatar
Engine: 383
Do you work on your car at all??
Old Mar 22, 2004 | 02:37 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i use a tiny jack my brother got from walmart to get it up enough so i can get the big craftsman under there.. other then that its a 2 person job.
Old Mar 22, 2004 | 03:41 PM
scott's85T/A's Avatar
Mine has been lowered about 1½" with sportlines and I can still get a regular hydrolic jack under mine.
But I lift the front under the A-arms and rear on the axle.Maybe thats the diffrence. :werd:
Bubbajones_ya
Jul 6, 2024 08:32 PM
Magman
Aug 2, 2016 08:32 PM
jbates346
Oct 21, 2015 01:50 PM
F-body-fan
Sep 19, 2015 09:02 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
