Guages in cowl?
Old Mar 26, 2004 | 09:52 AM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
Guages in cowl?
Does anyone have autometer gauges mounted inside a cowl?
I'm thinking about putting some inside the cowl of a stock formula hood...sneaky sneaky...
if you have, post pics.
Old Mar 26, 2004 | 10:10 AM
IceBlue91z28's Avatar
Car: 1991 Camaro Z28
Transmission: Built 700r4
do a search for BOTTLEDZ28 i know him and he had autometer gauges in his cowl and im sure he posted pics of them on here before i just cant find them
Old Mar 26, 2004 | 11:29 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Old Mar 26, 2004 | 11:42 AM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
I believe Dirk has them in his RAI hood also. Search for his car in Reader's Rides, that might show you at least one example.
Old Mar 26, 2004 | 12:44 PM
scauffiel's Avatar
Here ya go.
S.
scauffiel's Avatar
Another.
Old Mar 26, 2004 | 12:45 PM
scauffiel's Avatar
Final.
S.
Old Mar 26, 2004 | 03:24 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
thanks.
what size gauges are those?
i was hoping to find someone with them in a stock formula hood, but at least that in car shot lets me see how they look from inside the car. I dont like taking my eye off the road to look at anything.
Old Mar 26, 2004 | 05:25 PM
scauffiel's Avatar
IIRC they're either 2 1/2" or 2 1/4" - and the only problem is glare will occasionally make them hard to see, but it's not too bad.
S.
Old Mar 26, 2004 | 07:27 PM
BOTTLEDZ28's Avatar
Transmission: A4
here is a pic of mine. if it dont load then click the link
Old May 9, 2004 | 10:51 AM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
what is the thing to the left of the air/fuel gauge?
Old May 9, 2004 | 11:29 AM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
Looks to be a shift light!
Old May 9, 2004 | 07:03 PM
BOTTLEDZ28's Avatar
Transmission: A4
yep, its a shift light all right. Its a Harlem shift light. I never hooked it up though. I have since sold that hood and gauge setup and have begun working a new guage panel for my new 4" hood
Old May 30, 2004 | 06:40 PM
88fbird's Avatar
Car: 84 S-10:(
Stock formula hood? Here you go. Just look close.
Old May 30, 2004 | 06:42 PM
88fbird's Avatar
Car: 84 S-10:(
Another one. Sorry, by the way, I took these at night.
Old May 30, 2004 | 06:56 PM
White91GTA's Avatar
Engine: 5.7L TPI
gauge overlays look good.
Old May 30, 2004 | 07:20 PM
88fbird's Avatar
Car: 84 S-10:(
Thanks. I'm in the process of redoing them. I need to get rid of the ones I replaced in the hood. Only if I had some extra time!
FBird
Old May 31, 2004 | 09:45 PM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
Are you guys using some kind of brackets to hold them in? What about sealing them? Using some kind of rubber gasket I assume? How do you protect them from rain and such?
Old May 31, 2004 | 10:05 PM
88fbird's Avatar
Car: 84 S-10:(
I just cut a piece of sheetmetal that fit the same as the stock one. I made it a little long on the bottom. You don't see all of the gauges, but you see enough. I didn't seal them with anything. There is a slight overhang from the cowl that protects them the most. Sometimes they get a little clowdy, but it never lasts. The heat from the engine is like a big defrost for them. They are very easy to see while driving. Sort of like a heads up display!
Old Jun 1, 2004 | 05:25 PM
BOTTLEDZ28's Avatar
Transmission: A4
I secure mine in with O rings. I just stepped up to a 4" hood and replaced all the 2 1/1th gauges with silver 2 5/8" gauges. I i will post pics when its done. As for the O rings, I got some 2 1/2" ones and they slide over the back of the gauge real tight. I used 2 on each one.
sheachopper
Jul 31, 2019 11:27 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
